I have a mostly complete E36 OBD1 manual engine conversion. These parts were all removed from a 1995 M3 with manual transmission.
You get the following:
-manual engine harness from '95 M3 (X20 plug needs to be reconnected, but I have it to include with sale or will install an E30 C101 for an additional fee)
-good OBD1 knock sensors
-good OBD1 crank sensor
-good OBD1 cam sensor
-good OBD1 coil packs/boots
-good OBD1 engine temp sensor
-OBD1 intake manifold with air temp sensor
-OBD1 fuel rail with injectors (19#)
-OBD1 throttle body with good TPS
-OBD1 oxygen sensor
The only things you will need are an intake boot, OBD1 valve cover and a red label 413 DME with the proper tune for your engine.
$450 picked up for all this stuff, OBO.
-OBD1 oxygen sensor
