5 Lug e30 Partout + S62/ 6 Speed Part Out
  • 318isbmw
    • Nov 2005
    • 2841
    Before I list this everywhere, here are the parts I have for the car to begin with. I've just started taking the car apart this afternoon, I will take pictures as I remove the parts, otherwise let me know what you're interested in and I will prioritize removals accordingly.
    E30 Partout
    S50/ZF 5 speed Complete Swap - Engine/ Transmission/ Cooling system/ Driveshaft - $3000
    Suspension:
    1997 e36 M3 Control Arms/ Spindles/ Brakes (replaced discs and balljoints 6 months ago) - $300
    Treehouse Eyeball Arms (used 6 months) - SOLD
    BW Stainless Brake Lines (used 6 months) - $75
    Rear e36 M3 Brake Adapters 318ti (300mm.de adapters, new discs/Hawk HPS Pads) - $450
    Rear 318ti Trailing Arm(Rear left side) - $75
    Rear Condor Blackbird Kit(Subframe/ RTAB/ Diff bushings) - $175
    Koni Rear Shocks(Used 6 months, great rebound) - $120
    BW Swaybars (no front adjusters) - $400
    Vorshlag Camber Mounts (for Koni shocks/ used 6 months) - $300
    Rear Strut Brace - $60
    Interior:
    E30 Black Sport Seats/ Door Panels (4 door) - $450
    Uncracked Dash - $100
    4 door Black door panels - $40
    Exterior:
    16x8 style 5's (3 good wheels) - $150
    318ti Antenna (new grommet) - $60
    S62/ 6 Speed Items
    Good Condition block - $500
    Crank - Sold
    Rods/ Pistons (good condition when removed) - $250 for the set
    Cylinder Heads – ~50,000 miles on them (With documentation of replacement) - $750
    Vanos Assemblies - $Sold
    JB Racing Clutch (has some surface rust from sitting out of the car but only has 1,000 miles on it) - SOLD
    Brecus Motorsports Stage 2 Clutch (1,000 miles on assembly) - SOLD
    Coils (have 4 of them) - $20 each
    Valve Covers (missing passenger side coil cover) - $150
    ITB’s - $200 for the set of 8
    Exhaust Manifolds - $100
    Wiring Harness - $300
    Complete oilpan assembly including pump - SOLD
    Front Timing Covers (upper and lower) - $100
    Starter (good working condition) - $75
    Evolve tuned ECU (Alpha N Tune with secondary air pump delete) – $750
    Heat Exchanger Delete Plate - $150
    Throttle Solenoid - $50
    Injectors + injector rails - $150
    Getrag 420 Transmission (75,000 miles/ has broken rear mounts, however will come with new rear housing) - $1000
    Onto the pictures of some of the parts:
  • Matt-B
    The Waffler
    • 3856
    bump for a great seller, goes out of his way, to accommodate people.
    • Wschnitz
      • 8089
      I want this thing so bad, would be so sweet in an E36 Sedan.
      willschnitz
      • 318isbmw
        • Nov 2005
        • 2841
        It could be yours...
        • e30austin
          • 15382
          He's too much of a purist, anyway.
          Someone fund this man's next endeavor!
          • Wschnitz
            • 8089
            :p the only reason the e30 doesnt have an m54 is money, been waiting for the right motor to pop up for me to rebuild.
            willschnitz
            • 318isbmw
              • Nov 2005
              • 2841
              Because there is more money in the parts individually, I'll probably part it out next weekend if no one is interested in the entire package by then.
              • spiDmang
                • 3941
                Oh no!! The cosmos sedan got wrecked?? :(
                Bump for a good guy
                91' 318iS - S54/6MT Swapped
                08' E90 M3 6MT - Daily
                Originally posted by IronJoe
                Originally posted by 2mAn
                • 318isbmw
                  • Nov 2005
                  • 2841
                  Bump for a good guy
                  Yeah, got t boned pretty hard.
                  • 318isbmw
                    • Nov 2005
                    • 2841
                    Tough to sell just a clump of parts, so going to part out the motor and transmission.
                    • mooseheadm5
                      • Apr 2009
                      • 375
                      Definitely want the crank. Might want more, but I need to do research.
                      -P
                      Moosehead Engineering
                      • 318isbmw
                        • Nov 2005
                        • 2841
                        PM replied
                        • 318isbmw
                          • Nov 2005
                          • 2841
                          Vanos sold, crank is pending.
                          • EN318isPDX
                            • Oct 2007
                            • 4373
                            Willing to sell just the bell housing?
                            • mooseheadm5
                              • Apr 2009
                              • 375
                              I never got a PM from you on the crank.
                              -P
