FS: m30b35 harness and ECU from 93 535i/5
    Uncut, comes with idle air control valve,179 ECU, and o2 harness. No connector to c101. All connections aren't broken, but the sheathing is a little brittle.
    Asking 170
    Bump.
    145
      Hi,
      Would this work on a e23 745i 3.5 running a manual? What are the MAF/ chip options with a 179 ecu?
      Thanks
        This harness would be used for motronic 1.3 conversion. I onow there are quite a few chips available for the 179 ecu, including turbo chips. Don't quote me on that, do a quick search to see what you have available
          Yes it will work with that engine. I am running that set-up now in my e30. You would want to chip it to handle the boost and larger injectors.
          m106 1990 e30
          e36 daily
          e32 cruiser
