[solved] Help! Stuck on I5 at Longview exit, need caliper bolt
    Hi all, I was traveling north from Portland just a little while ago and I noticed a grinding from the front drivers side caliper. Took the wheel off and notice that the top caliper bolt is missing! I just got off 14 west after some spirited driving and it must have vibrated itself out or I didn't tighten it down enough when I inspected them last.
    Does anyone from the Portland/Vancouver or surrounding areas have a spare caliper bolt they can swing by? I will compensate you for your trouble
    Thanks
    -Evan
    304.906.7652
    '99 e46 323i - wrecked
    '87 e30 325iS - sold
    '91 e30 325i - sold
    '89 e30 M3 - fun car
    '09 e91 328i - sold
    '97 impreza - rally car - flipped
    '08 impreza - new rally car
    '01 996 tt - more fun car
    '82 Ford f350 - work truck
    Wishno87 messaged me and got me a bolt, thank you to everyone else who has offered help and assistance, I really appreciate it!
    Will try to pay it back in the future to someone else in need
    '91 e30 325i - sold
    '09 e91 328i - sold
      Consider yourself luck, that the caliper didn't cam lock against the wheel..
      2016 Ford Flex
        Very true, although the top bolt is the one which fell out, so i was lucky in that regard. All that happened was the caliper pivoted on the lower bolt and still performed while grinding against the edge of the rotor. Had it been the bottom bolt that came out, it would have, as you said, slammed against the inside of the wheel as the caliper grabbed hold of the rotor.
        Pretty scary stuff, i am putting locktight on all these bolts from now on
        '91 e30 325i - sold
        '09 e91 328i - sold
