Parting drift car!
    Parting drift car!
    Hey guys,
    Everything is being parted because I am leaving the military and moving back to Tennessee within a few months and I am already towing an S14 and having someone drive my M3 across the country while I drive the moving truck.
    It kills me to have to Part out everything I have worked so hard to Learn and Build for the Past two years, but I hope someone will enjoy the parts as I have.
    Please PM me with Parts you want (Listed or Not)
    All Prices are O.B.O
    Prices That have "Package" Next to it, indicate all of the below parts included. Otherwise parts are priced each.
    PRICES DO NOT INCLUDE SHIPPING! (Unless we work something out)
    ENGINE - $4000 OBO SOLD
    THE FOLLOWING IS FOR THE FOLLOWING + ACCESSORIES
    1997 S52 3.2L
    65k Before Complete Rebuild.
    < 1 Mile on Rebuild.
    Cylinder Head: Work Performed
    Thermally Cleaned
    Mounting Surface Decked
    Mounting Surface Crocus Cloth Polished
    Camshaft Journals and Caps Crocus Cloth Polished
    New Intake Valves
    New Exhaust Valves
    New Valve Springs
    New Valve Spring Seats
    New Valve Retainers
    New Valve Guides
    New Valve Keepers
    New Valve Stem Seals
    New Hydraulic Lifters
    New Camshaft Studs and Hardware
    All Threads Chased and Cleaned
    Complete Top End Gasket Set
    New Aluminum Thermostat Housing
    New 88 Deg C. Thermostat
    New Thermostat Housing Hardware
    New Vanos Unit Plugs with Seal Ring
    New Timing Chain Tensioner
    New Upper Timing Chain Guide Rail
    New Upper Timing Chain Hardware
    New Vanos Chain Tensioner
    New Valve Cover Studs (Cylinder Head to Valve Cover)
    New Valve Cover Securing Nuts
    New Cam Oil Cover
    New Cylinder Head Flange
    Engine Block: Work Performed
    Thermally Cleaned
    Magna-Fluxed
    Block Painted White with Heat Resistant Paint
    New ARP 2000 Studs Installed
    Head Mounting Surface Crocus Cloth Polished
    Oil Pan Mounting Surface Crocus Cloth Polished
    Crankshaft Main Journals Crocus Cloth Polished
    Crankshaft Connecting Rod Journals Crocus Cloth Polished
    New Oil Squirters
    New Glyco Main Bearingswaffles
    New Glyco Rod Bearings
    New Connecting Rod Bolts
    New Main Bearing Bolts
    New Front Main Seal
    New Rear Main Seal and Hardware
    New 45mm Freeze Plugs
    Complete Bottom End Gasket Set
    New Metal Head Ringed Gasket
    New Timing Chain Rail - Crankshaft to Exhaust Cam Chain
    New Flywheel Bolts
    New Complete Oil Filter Seal Kit
    New MAHLE Oil Filter
    New Aluminum Water Pump With O-Ring
    New Serpentine Belt
    New Clutch Pressure Plate to Flywheel Bolts
    New Upper and Lower Timing Chains
    New Oil Pump Chain
    E28 Green Engine Mounts
    M50 Oil Pan
    New Clutch Disk (Sachs)
    NEW Oil Pan Gasket
    NEW Oil Filter Housing Gasket
    VIDEOS OF IT RUNNING.
    Intake:
    M50 Manifold
    New Manifold Gaskets
    New Intake Manifold Idle Stabilizer
    New Intake Manifold Studs
    New Throttle Body Hardware
    New Throttle Body Gasket
    NEW E34 Throttle Cable (Broken Retaining Clip)
    Exhaust:
    Raceland Shorty Headers
    New Metal Gasket Set
    New Exhaust Studs
    New Copper Exhaust Collar Bolts
    New OBD2 02 Sensors
    WIRING - $200 OBO
    OBD2 Wiring Harness Hard Wired (Fuel, Ignition, Starter)
    Blue Sea 5031 ST Blade Fuse Block (12 Circuit with Negative Bus)
    ANL In-Line Fuse Block
    "Hella" Master Kill Switch with Removable Key
    Individual 30a Relays (I have 10)
    TRANSMISSION - $200 OBO
    5 Speed GETRAG
    SOLD - Garagastic Swap Brace
    SOLD - NEW Clutch Slave Cylinder
    ENGINE MANAGEMENT - $400 SOLD
    Kassel Performance MS41.2 TUNE with M50 MANIFOLD
    +12Hp +10Tq
    7,200 Rev Limit
    EWS Delete
    Secondary Air Pump Delete
    Post-Cat O2 Sensors Delete
    Muffler Flap Delete
    No Emissions CEL
    WHEELS + SUSPENSION - OBO
    SOLD - NEW BC Racing BR Type Coil-Overs 10k Front 12k Rear
    SOLD - (x4) 17x8 Square: BBS RC090 Style 5's (Has Center Caps, Missing Some Hardware)
    $200 - (x4) Brake Rotors and NEW Pads
    SOLD - (x2) 20mm 4x100 Spacers
    SOLD - (x2) 5mm 4x100 Spacers
    $15 - (x8.) 5mm Extended Lugs
    $10 - (x8.) Regular Lugs
    OTHER PARTS PACKAGE - OBO
    $300 - SPARCO SPEED 2 Racing Seat
    $200 - ASD Motorsports Upright Hydraulic Hand Brake with Willwood Master Cylinder and 5/8ths Pass-Through Kit with Hardware
    $200 - Complete Black Interior
    $100 - Front Subframe
    $100 - Rear Subframe
    $100 - Team Tech 5-Point Racing Harness
    SOLD - E30 VDO CLUSTER 143,348 Miles Perfect Condition
    SOLD - E36 Steering Rack
    $50 - E30 Steering Rack
    PENDING $50 - S52 AC UNIT
    $50 - E30 ABS UNIT
    $50 - LCA (EACH)
    SOLD - 18LB BOSCH Green Top Injectors
    $50 - OBD2 Fuel Rail
    $50 - OBD2 Throttle Body
    $50 - Sway bar + Hardware
    $25 - Early Steering Wheel
    $25 - Box of Random parts
    Offer - Misc Trim Pieces
    BODY PARTS - OBO
    All Parts are Alpine White
    $300 - Shell (Gutted, Sound Deadening Removed, Tubular Front, Rear Tire well Cutout)
    PENDING $75 - Dash NO CRACKS
    $50 - Each Sedan Door (Glass Included)
    $50 - Trunk
    $50 - Hood (Has Cutout over Exhaust)
    $50 - Tail Lights with Pig Tails
    PLEASE ASK ME IF YOU NEED SOMETHING THAT IS NOT LISTED!
    DESTROY GARAGE
    S T R E E T S T Y L E
    @CRISMACSTUDIO
    FREE SHELL, COME GET IT!
    Hey - coilovers available? I'm in Seattle, definitely interested. PM'd.
    4 doors.. so much room for activities!
    IG @bluebombr
    Transaction Feedback:
    http://www.r3vlimited.com/board/showthread.php?t=323622
      you have reply ncsubowen.
      DESTROY GARAGE
      @CRISMACSTUDIO
        UPDATED ITEMS -
        Engine + Management PENDING - Sirjustinderek
        BC COILOVERS SOLD - ncsubowen
        18# INJECTORS SOLD - see.m3.go
        VDO CLUSTER PENDING - dishwab
        20mm, 5mm Spacers SOLD - Simple Smith
        DESTROY GARAGE
        @CRISMACSTUDIO
          You happen to have the stock shift knob and want to sell!?
            No i actually don't. I think I threw it away when I was gutting the car.
            DESTROY GARAGE
            @CRISMACSTUDIO
              UPDATED ITEMS -
              VDO CLUSTER SOLD - dishwab
              ALL SOLD PARTS HAVE SHIPPED OUT!
              Have tons of parts left, Come out to the house and take a look! Need this stuff gone gone gone!
              DESTROY GARAGE
              @CRISMACSTUDIO
                After Xmas SALE!
                OFFER UP!!
                DESTROY GARAGE
                @CRISMACSTUDIO
                  UPDATED ITEMS -
                  Engine + Management DEPOSIT
                  BC COILOVERS SOLD AND SHIPPED
                  18# INJECTORS [COLOR="Red"SOLD AND SHIPPED[/COLOR]
                  VDO CLUSTER SOLD AND SHIPPED
                  20mm, 5mm Spacers SOLD AND SHIPPED
                  BBS STYLE 5s SOLD
                  ASD HYDRO + HARDWARE PENDING
                  COMPLETE DASH PENDING
                  E36 Steering Rack SOLD
                  Giggty Giggty! Offers Welcome!
                  DESTROY GARAGE
                  @CRISMACSTUDIO
                    UPDATED ITEMS -
                    BC COILOVERS SOLD
                    18# INJECTORS SOLD
                    VDO CLUSTER SOLD
                    BBS STYLE 5s SOLD
                    ASD HYDRO + HARDWARE SOLD
                    COMPLETE DASH SOLD
                    Still plenty of parts left.
                    If someone wants to come pickup the shell, I will give the Interior away with it. Must bring a trailer, there are no wheels or suspension on the shell.
                    DESTROY GARAGE
                    @CRISMACSTUDIO
                      UPDATED ITEMS -
                      Engine + Management SOLD
                      BC COILOVERS SOLD
                      18# INJECTORS SOLD
                      VDO CLUSTER SOLD
                      BBS STYLE 5s SOLD
                      COMPLETE DASH SOLD
                      If someone wants to come pickup the shell, I will give the Interior away and a few boxes of random parts with it. Must bring a trailer, there are no wheels or suspension on the shell.
                      DESTROY GARAGE
                      @CRISMACSTUDIO
