84 318i wont crank over/start
  • jonnywadster
    • Mar 2015
    • 58
    New starter/battery.
    In the Vancouver washington area, anyone around me know these cars?
    Kind of baffled that I can't get the car to turn over, I could of hooked up the starter wrong.
  • SketchyRex
    • Feb 2012
    • 242
    Check ground.
    • LuckyHenriksen
      • Jun 2010
      • 4244
      x2. Check all the grounds and battery terminals and make sure they are clean and tight
      Bahama Beige E23 Project
      Bluebird Bus Conversion
      New Oregon Trail
      • FireFight
        • Mar 2012
        • 1367
        Ground strap, then check that the black with yellow stripe wire is plugged in to the lower spade connector that's the trigger wire. But if you have an auto then make sure your in park, if you are and it still doesn't work try neutal
        WTB:m60b40 in PNW
        Zachary Ripley
        85 318i M50B25tu.
        92 525it 5 speed.
        80 244gl (m60 prepping).
        • jonnywadster
          • Mar 2015
          • 58
          Okay I got it to start now it just won't idle.
          • FireFight
            • Mar 2012
            • 1367
            Go though and do a tune up on it. M10s are cheap, then check for vacuume leaks.
            Check your firing order aswell that can be throwing you off.
            WTB:m60b40 in PNW
            Zachary Ripley
            85 318i M50B25tu.
            92 525it 5 speed.
