Need to get m52 swap parts, need to get rid of e30 parts
  • ColonelMustard
    • Jun 2013
    • 120
    Hey I'm in the middle of swapping in an M52 to replace my eta. I'm looking to pick up some parts for the swap. PM me if you have something to offer or if I have something you want. Located in the Seattle Area
    Parts I'm looking for:
    e34 oil pan, sump, dip stick tube
    radiator - late e30 or e36
    single mass flywheel and starter
    Parts I can trade/barter/sell
    e30 Rear Ashtray
    e30 Front Ashtray
    stock Steering Wheel
    brand new Washer level sensor
    Windshield wiper motor and assembly (one joint seperated on linkage)
    Alpine Coaxials
    A pillar covers
    325e valve cover
    New Center Shaft Bearing
    Houndstooth Cloth Comfort Seats (Front and Rear)
    Car Amplifier 4-Channel (Boss PH4.600 Phantom 2400 Watt) Never used
    Timing belt cover gasket lower
    cam shaft seal
    Timing Belt and pulley
    Radiator Hose Lower
    water pump
    Radiator Hose Upper
    engine mounts
    New Distributor Cap (Bosch)
    oil filter
    front sway bar bushings
    Throttle Position Sensor
    Thermo-Time Switch
    cold start valve
    ecu with turner performance chip installed
    I'll try to get some pics of the seats tonight, and anything else a person could want a picture for.
    1987 325 w/ M52b28 - Bronzit
    2007 X3 - Platinum Bronze
  • e30austin
    • 15382
    I've got an E34 V8 booster (same as the iX) that I would sell...PM me if interested.
    • spiDmang
      • 3941
      I have an e34 throttle cable you can have for a Dicks Deluxe and a strawberry shake lol. The M42 is nice for its adjustability, but the E34 cable is known to work as well.
      91' 318iS - S54/6MT Swapped
      08' E90 M3 6MT - Daily
      Originally posted by IronJoe
      Originally posted by 2mAn
      • EN318isPDX
        • Oct 2007
        • 4373
        Pmed
        • DeM3n
          • Mar 2005
          • 1260
          I've got a brand new e34 throttle cable, plug and play wiring harness for a 318i to m50 wiring harness, e21 brake booster unmodified, euro TOB too. Think I have the Garagistic tranny bracket with mounts unused.
          Sent from my SM-G920V using Tapatalk
          • ColonelMustard
            • Jun 2013
            • 120
            Pm'd
            • ColonelMustard
              • Jun 2013
              • 120
              I forgot to mention that I have the m20b27, engine harness, airbox, dual-mass flywheel and a number of other parts that won't go back into the car. Let me know if you're interested. The motor had low compression in cylinder 4 and started to miss fire.
              It can all be yours for cheap. Just shoot me a PM.
              • ColonelMustard
                • Jun 2013
                • 120
                Drivers seat
                Drivers seat back frame sheared near the top. Would be an easy fix
                Passenger seat
                Rear Seat
                eta Ecu with turner chip installed. Give that economy engine a kick in the pants.
