Help Needed Near Seattle
  • Appleseason
    • Jan 2017
    • 124
    Hi All,
    I live in Federal Way, and need help from another E30 owner. All I need to is barrow the gauge cluster, put it into mine for a bit, then give it back. I need to make sure that my gauge cluster is the problem and it is not something else. I can give beer if you want.
    Private message me if interested.
    Thanks :):):)
  • Appleseason
    • Jan 2017
    • 124
    Saturday bump
    • Matt-B
      The Waffler
      • 3856
      what is the issue?
      • Appleseason
        • Jan 2017
        • 124
        Originally posted by Matt-B
        what is the issue?
        Problems with my instrument panel, the coolant gauge does not work properly. It is not any of the common things so I would like to try out another cluster to see if my cluster is the problem.
        The troubleshooting thread is here:
        • 2002jm
          • Sep 2005
          • 2076
          You have checked the tightness of the ground on the back of the gauge:)??
          jm
          • deutschman
            • May 2008
            • 5958
            http://www.r3vlimited.com/board/showthread.php?t=401216
            Take the cluster out, and then tighten the little nuts on the two small gauges on the far left and right of cluster. 90% of the time this is the issue. If the nuts are loos the gauges dont get grounded correctly and go crazy.
            • Appleseason
              • Jan 2017
              • 124
              jm
              That was the first thing I tried, It was already tight, but I sanded the posts still, and nothing changed.
              • Appleseason
                • Jan 2017
                • 124
                Bump, still need help finding a cluster to barrow
