NEW STUFF FORSALE NO PANJO SHOOT ME A TEXT OR PM
M20 2.7i stroker motor - 350 whole, w/ harness no intake manifold, has oil pan
Will sell 885 head & arp studs - 200 Firm
Parts under 5k use
Arp head studs
Headgasket kit (elring)
Front&Rear main seals, oil pan gasket,
Water pump (late model)
Thermostat
Gates timing belt, tensioner & spring
Clean late model intake mani & 19lbs yellow top injectors, were refurbished by PO under 1k, with injector harness, rail - 135
Dirty Late model intake mani x2 - 60 ea
Clean late model intake mani - 75 ea
19lbs yellow top injectors, were refurbished by PO under 1k - 75
Ellips missing drivers high beam, pigtails not included for now working adjusters no broken mounts - 75
Ellip set for parts - 40
Late model valve covers x2 - 35 ea
25mm Brake booster w/ resevoir, ate late model under 500 miles pretty much new from ecs - 150 will include stock booster
L Shape ICV w/ new intake boot- 60
Late model afm - 75 ea (have 3, two known working)
89 Manual drive shaft - 150 (with guibo and csb)
89 g260 with infamous g rattle, Shifts great no grinding rattles in neutral fresh redline fluid - 200
Condor m20 engine & tranny mounts, 2sets - 60 ea
13 button obc missing stalk - 50
Have several late model DME including a couple 173's - 50 ea
Late model strut assemblies - 100
3.73Lsd Low miles fresh fluid - 300
Have a bunch of other late model m20 parts
throttle bodies, thermo housings, wire harness, injectors harness, coolant hoses, the list goes on if you see something not listed just shoot me a text
m50tu 120k pulled from a rear ended e34 wagon, wire harness included have most of the sensors along with a new graf water pump NO E34 OIL PAN! will included a e36 oil pan if needed, with exhaust manifold
- 350 will part out if enough interest is there.
m50 intake manifold - 75 ea
s52 intake manifold - 75 ea
e34 intake box with MAF M50 - 75
Can take more pictures of items you may want for serious inquiries
ALL PRICES OBO
Link to CL only for the pictures my pictures on here never work.
If you want more shoot me a text , and trying to keep shipping to a minimum but ill make some ecceptions for R3v members.
Parts under 5k use
Arp head studs
Thermostat
ALL PRICES OBO
