Hi all,
I am a long time lurker of this forum selling my 1991 318i. It is a 5-speed manual. Looking for $2200 for the car and extra parts. It has 251,000 miles on the chassis and 161,000 on the engine that is in it. The car is mostly stock with the exception of an aftermarket stereo, aftermarket exhaust, and DIY cup holders in the center console. Some of the recent mechanical work done to it:
-New alternator, 236,808 miles
-New brakes and replaced rear caliper, 239,329 miles
-Engine replacement (155k), 245,637 miles
-New Clutch, 245,637 miles
-New Water Pump, 245,637 miles
-New Spark Plugs, 245,637 miles
-Used upgraded exhaust (high flow resonator and Magnaflow muffler), 245,637 miles
-New Rear Tires, 245,709 miles
-Last Oil Change, 249,420 miles
Link to pictures here:https://imgur.com/gallery/Wfo3jVR
Cons of this car are:
-Power Steering leaks
-A/C is blowing fuse 20
-Fuel gauge does not work
-Clear coat is peeling (can be seen in photos)
-Rear driver side door central locking does not work
-Front seats are torn and do not match the rear seat.
From the recent engine replacement, the car will also come with extra parts. Including, but not limited to:
-Starter
-Alternator
-MAF sensor
-Valve cover
-ECU
The car will also come with a set of wheels and snow tires (tires need to be mounted). There is also a 5th basket weave wheel that can be used as a spare (Has steelie full size spare currently). Message me if you have any questions or want to take a look.
-Starter
-Alternator
-MAF sensor
-Valve cover
-ECU
