I am putting the tranny back in my car and need a deep well 30mm socket, if anyone lives close to me (Halls/Gibbs) and could help me out with the socket for like 5 minutes I would be in your debt, I just spent a lot of $ and I am broke in E30 goodness for the month now says the wife lol.
Knoxville Little Help
What do you need a deep well 30mm for? Putting trans back into car doesn't require that size socket.
Sent from my 831C using Tapatalksigpic
Rebuilding since 07/06/2016
Poorboyz Parts For Sale - Updated 01/20/17 - Will be updated soon - Have many parts to post
Poorboyz Feedback ThreadComment
The trans from the 86 has the small output shaft/guibo, so I have to take the output shaft off my old tranny and swap it over. The trans I have is the exact same trans model number and all but the output shaft to driveshaft triangle is different. I am glad I kept that tranny now lol.sigpic87 325E The Honey BadgerComment
Good deal! You might need to heat up the nut because sometimes it won't back out due to the red loctite used.
I also tried texting you some pics of the tool I made to split case open but the texts won't go through. PM me a working number or email I can send you some pics to help you if needed.
Mapp gas would be plenty I would guess.Originally posted by Andy.BWhenever I am about to make a particularly questionable decision regarding a worryingly cheap diy solution, I just ask myself, "What would Ether-D do?"Comment
Also I hear you can rest a big combo wrench across the trans mount bosses and under the trans flange so as to keep the flange from turning while you crank on it.
…../__\
0---------c
That triangle being the flange and the little ^ being the trans bosses. And I believe the combo wrench is a clear masterpiece of emoticon perfection...Last edited by Ether-D; 09-26-2014, 05:47 PM.Originally posted by Andy.BWhenever I am about to make a particularly questionable decision regarding a worryingly cheap diy solution, I just ask myself, "What would Ether-D do?"Comment
LOL roger that, I actually have a pipe fitters pipe wrench, I can set it to hold the triangle itself and have 20" of leverage. It will be like I made a tool to hold 2 of the 3 bolt holes in comparison but I also see no problem with what you also mentioned if said tools were not available.Also I hear you can rest a big combo wrench across the trans mount bosses and under the trans flange so as to keep the flange from turning while you crank on it.
…../__\
0---------c
That triangle being the flange and the little ^ being the trans bosses. And I believe the combo wrench is a clear masterpiece of emoticon perfection...sigpic87 325E The Honey BadgerComment
