Phoenix help with ABS?
  • Hoffbrohaus
    • Sep 2013
    • 519
    Anyone in Phoenix with working ABS willing to spend some time with me? I'd like to try your ABS controller (the one under the driver side dash) to see if my controller board is causing my problems before I spend more money.
    see this thread http://www.r3vlimited.com/board/showthread.php?t=310644
    '90 325is
  • Hoffbrohaus
    • Sep 2013
    • 519
    Anyone? Bueller? Guess I'll join azbmw.org too and hang out wit da kidz
    '90 325is
    • Holland
      • Nov 2008
      • 7212
      I would help, but my car is an 85, hence no ABS.
      Originally posted by DEV0 E30
      • ikonwun
        • Apr 2012
        • 374
        im deleting my ABS very soon if you would like to grab any part youre welcome to them\.
        • Hoffbrohaus
          • Sep 2013
          • 519
          Cool let me know when is good for you. At this point I just want to try out the ABS controller. If that doesn't help I'm not sure which way to go.
          '90 325is
          • ikonwun
            • Apr 2012
            • 374
            you can grab it from me from work 8-5 mon-fri in tempe or in chandler any other time \ weekends.
            still in the car I would have to pull it or you could .
            pm me for my number
            • DesertBMW
              • Aug 2011
              • 1038
              I deleted my ABS from 1989 coupe so I got all the parts. You should remove all of your ABS wheel sensors and clean the trigger ring, it gets dirty and loaded with junk and it could cause sensors not reading. Also sensor tip is magnetic so metal shavings get loaded on it, that could also cause no reading.
