90 325i part out ATX
    Totaled my 325i. I a lot of the interior is in good shape same with the back end and all the original glass. The motor was just rebuilt about 4k miles ago. I would like to sell the motor as a whole. It has ARP head studs fresh timing belt and water pump. PM me and I will let you know if I have it and what condition it is in.
    I would like to get about $900 for the motor ( thats less than half of just the motor work that went into it just at the shop)
    Here is a picture pre-accident
    This is as it sits now, I have the cap and wires still took them off so I could get the radiator out.
    [URL=http://s62.photobucket.com/user/e30kawi/media/IMG_20140126_113106_531_zpsd71108f2.jpg.html]
    I forgot to mention a lot of stuff I have on here, it has
    urethane motor and transmission mounts,
    its a 5 spd with a new slave cylinder,
    New master cylinder mount bushings
    New rubber fuel lines
    it has a 3.73 LSD rear end with fresh fluid,
    The rear subframe has the reinforcements welded on to it already with I believe the toe adjustment,
    It has IE billet urethane rear shock mounts
    New Shocks all around, but the drivers side front might be bent
    I have the IE Stage 3 springs with the rear spacers
    according to the paperwork it has a new guibo
    New front strut bushings
    It has a flow master muffler
    Ask me and I will see if I have it
    saw first pic. got excited it was silver. started to send pm about front valance. then saw the rest of the pix....
    Gigitty Gigitty!!!!
      I might want the rear subframe and suspension. Were you selling this on CL for like $6k not too long ago?
      Sent from my SAMSUNG-SGH-I727 using Tapatalk
        Yeah, I had a really optimistic price up there...but it is less than I have in it, I know you don't get what you put in but I wasn't really expecting to sell for that much. Beginning to think I should have taken that $2800 I was offered...
        Let me know if you want that subframe and suspension, I checked, the drivers side shock was toast, so I have the rears and one front, the passenger side control arm has new ball joints and control arm bushings if you're interested in that too. I have only had the car about 14 months so everything I did to the car is maybe a year old and the motor was re-installed at the end of April beginning of May.
          How are the bushings on the subframe?
            I am not sure, they were in there when I bought the car. I will have to take a look at them next time I crawl under it.
              I need to replace mine, but would rather swap one in with adjustments and better bushings. Can you check the drivers front shock too? I might pick up the whole suspension from you too if it's in good shape.
                I checked, the drivers side shock was toast, so I have the rears and one front, the passenger side control arm has new ball joints and control arm bushings if you're interested in that too. The IE stage 3 springs and the rear spring spacers are in good shape.
                I haven't had a chance to crawl back under the car to check the condition of the bushings yet.
                  I might be interested in the engine. Still looking into if im going to rebuild my m20b23 or if im going to swap in a b25.
                  89 325i Coupe Auto Delphin Metallic - Sold
                  91 325i Sedan Auto Brilliantrot - Sold
                  83 323i Euro Coupe Manual Lapisblue - Sold
                  89 325i Coupe Manual Delphin - Sold
                  89 325i Sedan Auto Brilliantrot
                  87 325i Vert Manual Brilliantrot
                    A rebuild isn't cheap, unless you can do it yourself but even then it can be spendy. I am trying to find a shell to ram this one into so I don't lose so much on it.
                      Yea im just considering the rebuild for the sake of keeping it stock. But i think the engine is too far gone for machining. If you still have the b25 after i pull my b23 here soon and i check it out i might snag this from you if its still available.
                        Would you be willing to sell the motor mounts? If so, how much? What was the drop with the IE springs?
