Hows it going everyone. Im hearing some noises coming from my car, i think its the front driver side tire or wheel bearing. i hear it when im doing about 30 mph. and ideas??
Noise.....
Tags: None
Take of the wheel, remove disc and then rotate the hub... if it turns over smoothly then its not the bearing. If it feels gritty or doesn't turn easily then I would bet that its your bearing.IG: deniso_nsi Leave me feedback here
Another way to see if the problem is a bearing is to get up to speed on a flat open stretch of road and then lightly turn left and then right. If you hear more noise when you turn left its the right bearing. If you hear more noise when you turn right its the left bearing.Comment
