Okay, the SRS on an e30 is the most simplest in design compared to modern airbag technologies. However, it is also the biggest pain because no one seems to be able to properly diagnose or reset it (yes, I've tried searching and the tricks didn't work)
For me, it all started during a dash swap and I neglected to disconnect the battery when unplugging the module. It was a Do'h moment after everything was reassembled and I have since lived with the flashing warning for the past 2 years that I've tried everything you can do to get it reset.
I guess my question is, can I simply remove a module from a donor car properly (w/battery disconnected), and re-install it into my car (w/battery disconnected), without triggering an error in the module?
