Selling a complete used moonroof setup for the e30. Shipping at buyers expense - I will make sure its packaged well.
Asking $1600 SOLD
Includes:
Only modification necessary to install on a standard sunroof equipped car would be to follow steps A and B of section III in the instructions (also in the linked folder). If you aren't comfortable with this, the alternative would be to buy the already modified cables I have below.
Also have other sunroof components I don't need that I am selling separately. Make an offer for these if you need anything along with the moonroof or if you need something on its own.
Asking $1600 SOLD
Includes:
- Glass moonroof panel - in good, used, shape with the usual light scuffs and scratches on the glass along with water spotting. I tried to capture everything in the pictures.
- Sunshade slider assembly - rough around the edges, but visible areas are decent. Could use a reupholstering. Black plastic panel on the top side is cracked around mounting points but still holding.
- Water channel - modified at some point in its life per the moonroof install instructions
- Left and Right side rails - specific to the moonroof, these replace the ones found in the sunroof
- 2 springs for water channel
- 2 longer screws for new rails
- BMW installation printed instructions
- Rear terminal strip
- Left and right side LOWER rails
- Wind deflector with 2 support arms
- Left and right side attachment gates (the arms the sunroof actually bolts into)
- Left and right side pilot brackets
- Electric sunroof access trim cover
- Electric sunroof motor
- Sunroof hardware
