Fs: Alpina steering wheel
  • e30rida
    • 963
    Very Nice Alpina Steering wheel. Fresh newly redone in original Nappa black leather with blue and green stitching. Vintage Original not repop. Dated 6-91. $498 Shipped.
Name:	WhatsApp Image 2022-09-20 at 2.17.44 AM.jpg
ID:	10068953 Click image for larger version
  • e30rida
    • 963
    If the MOMO hub adapter is needed I can add it for an extra $75
    • Bmwentertains
      • Aug 2022
      • 15
      Is this feasible on a 91' vert with airbag,?
      Sent from my SM-N970U using Tapatalk
      • e30rida
        • 963
        Yes, You will need the MOMO adapter off course if you don't have one.
        • e30rida
          • 963
          By adapter I mean this:
          If you’re looking to upgrade the steering wheel in your E30, this is your ticket This Steering Wheel Hub Adapter allows removal of your factory steering wheel and installation of your MOMO wheel, and retains both the horn button function as well as proper turn signal auto shut-off. Suitable for both street and track use Made in Italy using high grade steel & aluminum. Proven quality for 40+ years. Momo’s hub adapter will fit the most common 6-bolt steering pattern with a bolt spacing of 2.75 inches or 70mm. This includes MOMO, Sparco, OMP, NRG, Isotta and others. Hub Adapter, Black Rubber Cover Counter Sunk Screw Kit Hex Key Wrench Horn Slip Ring, Any horn wires as required Install Notes: -Does not allow for fit of the similar 6-bolt pattern Nardi / Personal wheels. We offer these specific adapters else ware in the steering wheel section. -Will eliminate Airbag if your E30 is equiped with one.
          • flipper325es
            • Aug 2009
            • 280
            It's entirely feasible, you'll need to use a spacer, BMW p/n 32311120260, in addition to a hub adapter.
            If you decide to buy this wheel and need a Momo adapter, I have an extra one, it's brand new.
            • e30rida
              • 963
              ttt
              • kronus
                • Apr 2008
                • 13020
                how were the horn button imprints done?
                cars beep boop
                • e30rida
                  • 963
                  With 300 Euros worth of work. But really have no idea. They do look exactly like they were originally. Been using the same guy for several years but you need to send it to Germany, about 60 days back and forth.
                  • Bmwentertains
                    • Aug 2022
                    • 15
                    Ok, an mtech 1 or 2 is supposed to sit closer to the dash needing new stalks (only read this, no first hand experience) is this the same case with this wheel? Does this sit closer to the driver or further?
                    • flipper325es
                      • Aug 2009
                      • 280
                      Momo hub is just under 3.5" tall. This is a flat wheel so the combo would be just over 3.5" tall to the center plane of the wheel. It would likely match the height of factory non-airbag wheels. If you have an airbag wheel, and would want this one to match the position, it's very easy with a spacer between the hub and the wheel -- they're available in different thicknesses.
                      This is one of the advantages of aftermarket wheels -- you can easily move them closer to the driver, by either using a dished wheel, or a flat wheel with a spacer of 0.5-3". Not easy to do with factory wheels with an integral hub.
                      • e30rida
                        • 963
                        For those who've asked here are more pics.
Name:	WhatsApp Image 2022-09-20 at 2.17.52 AM.jpg
                        • Digitalwave
                          is a poseur
                          • 6282
                          Guessing with a heated embossing die.
                          Great looking wheel!
                          RISING EDGE
                          • e30rida
                            • 963
                            Still for sale
                            • e30rida
                              • 963
                              bumpz
