Hey all,
I have a mess of new parts that are unopened that I need to get rid of.
Here is the list:
Pressure Plate Bolt, BMW E30 All, (1992-99), Each : Qty 8 - $8 shipped: SOLD
Exhaust Stud, Head to Manifold, 8 x 40mm, E21 320i; E30 318i/iC, 325/e/es/i/is/iC/iX; E12 528i, 535i; E28 528e, 533i, 535i; E34 525i/Touring, 530i/Touring, 535i; E24; E23; E32, As Needed: Qty 15 - $10 shipped: SOLD
Valve Cover Gasket, 325/e/es/i/is/iC/iX (1984-91) : Qty 1 - $20 shipped (not pictured)
Oil Pan Gasket, 325/e/es/i/is/iC/iX (1984-91) : Qty 1 - $25 shipped (not pictured)
Flywheel Seal (90 x 110 x 12) Original style seal that has a tension spring, E30 318, 325, M3 (1983-91), Each : Qty 1 - $9 shipped SOLD
Pilot Bearing, Ball Type, 12mm hole, 318i (1984-86), 318i/is (thru 08/90), 325/e/es/i/is/iC/iX (1984-91), M3 (1987-91) : Qty 1 : SOLD
Cover Plate for Felt Ring at Pilot Bearing, BMW E30 3 Series, All (1984-92): Qty 1 : SOLD
Cover Plate for Back Side of Pilot Bearing, BMW E30 3 Series, All (1984-92): Qty 1 : SOLD
Felt Ring for Pilot Bearing, BMW E30 3 Series, All (1984-92): Qty 1 : SOLD
Won't separate pilot bearing parts - $20 shipped for all SOLD
Flywheel Bolt, 12x28mm, 8 Per Car, 325/e/es Manual Trans. (thru 04/86), 325i/is/iC/iX (1984-91) : Qty 8 -$28 shipped :SOLD
Intake manifold gasket set complete for 'e'- $12 shipped :SOLD
Intake manifold gasket set complete for 'i'- $12 shipped :SOLD
Gasket, Throttle Body Housing to Intake Manifold, E30 325/e/es, Each: Qty 1 - $4 shipped :SOLD
Fuel Injector Seal (7.8 x 3.6mm), BMW E30 3 Series, 2 seals per injector, sold per each : Qty 12 - $15 shipped :SOLD
Copper Lock Nut, 10mm Exhaust Flange, 325i/is/iC (1992-95 ), 318i/is/iC (1992-98 ) 328i/is/iC (1996-99) 318ti (1995-99), M3 (1995-99): Qty 6 - $5 shipped :SOLD
Transmission Mount, Manual, (2 per car, sold per each) 325/e/es/i/is/iC/iX (thru 1991), Each: Qty 2 - $15 shipped SOLD
Early model shift bushing kit, complete: Qty 2 - $60 shipped 1 Pending Sale :SOLD
Flex Disc-Guibo Coupling, 6-Hole, E30 318i, 325/e/es (through 4/86), 325i/is/iC/iX, 318i M42: Qty 1 - $35 shipped SOLD
Camshaft seal M20: $5 shipped
Valve seal set (complete): $10 shipped :SOLD
Center Support with Bearing Assembly for Driveshaft, BMW E30 318i, 323i Euro (from 9/82), 325e/es (through 8/87), 325i/is (through 8/87) : Qty 1 - $25 shipped SOLD
US ellipsoids, no brackets. These have holes drilled into the housings from whoever had them last installing some sort of strobes. However, the projectors themselves are good and the glass fine as well. Most of the adjusters are included: $40 shipped SOLD
Early model sheet metal shift carrier and lever: $25+shipping :SOLD
Ground strap- main ground from pan to chassis: $10 shipped
BavAuto short shifter selector rod early model (square rod pictured): $20 shipped Pending Sale: SOLD
Stock early model selector rod: $10 shipped Pending Sale: SOLD
Pioneer cd deck with holder and harness DEH-P3700MP: $40 shipped :SOLD
E30 rear sunshade :SOLD
All parts are BO
Max
Here is the list:
All parts are BO
Max
