I'm located in Gainesville; GA. Shipping can be arranged for items at buyer’s expense. Tracking Number will be provided if shipping is arranged.
These parts are from an 88' and 89' 325is. All parts were in working order when they were taken off of my two part-out cars.
Here is my updated E30 parts list with pictures:
-New Kolbenschmmidt Main Bearing Set M20B25 Early model Engines SOLD!
(The Ref. number is: 11 21 1 265 459) The box and packaging has been opened but the bearings wear never installed. I was unaware that there was a difference between the early model m20b25 and the later model m20b25.
-M20B25 Block $100
(I have all the hardware for the block including the intermediate shaft, main seals, and more. Cylinder walls look good.)
-M20 2.5L Crank $90
(In good condition, ready to be shipped)
-Oil Pump (Good Condition) $50
-Starter (good condition) $50
-Throttle Body w/ throttle positioning sensor (In Good Condition)SOLD!
(This throttle body was off an 1989 325is with an m20b25 2.5L)
-Injectors SOLD!
[Ref. # 0250150715]
-Fuel Rail and Fuel Regulator $22
[B]-Fuel Injector Harness w/ plastic covering SOLD!/B]
(The Harness is off a 1989 325is with the m20b25 2.5L engine. This harness also comes with the metal bracket and plastic cover for the injector connectors.)
-Spark Plug Wires SOLD!
(This spark plug wire set is numbered 1-6 and comes with coil wire + pulse sensor.)
-3 Spark Plug Wire Covers $14ea.
(All covers are in good condition. Snap in and hold wires with no problems.)
-Bronzit Gas Tank Cap Flap $12
(Paint is in great shape)
-2 Ac Pumps $40ea.
(Both were in great working condition last time they were on my E30s. The first Ac pump is a Seiko Seiki pump with the Ref. #6452 1386 464. The other Pump is a Denso with the Ref. #64 25 1 386 256.)
Seiko:
Denso:
- AC Condenser w/ Aux Fan SOLD!
(Both the High and Low Speeds worked on Aux Fan)
-AC Receiver/Drier w/ Low-pressure switch, High-pressure switch $10
-Fan Blade with Clutch $25
(Fan Blade and Clutch are in good working order and did not make any noises.)
-Vibration Damper $15
(Teeth are in good shape)
-Pulley $13
[Ref. # 11231280958]
-Power Steering Pulley $13
-2 Stock Rear Sway Bars $15ea.
- Stock Front Sway Bar $20
-Front Sub Frame $34
(Off an 1989 325is Coupe)
-Power Steering Rack SOLD!
(Had no leaks or noises)
-Steering ColumnSOLD!
[Ref. #11534100]
-Steering Linkage SOLD!
-2 Clutch + Brake Pedal Assemblies SOLD!
- Gas PedalSOLD!
-Set of stock springs Front + Rear SOLD!
(Springs are off an 1989 325is Coupe)
-M20B25 Block $100
-M20 2.5L Crank $90
-Injectors SOLD!
[Ref. # 0250150715]
-2 Ac Pumps $40ea.
Seiko:
Denso:
-Pulley $13
[Ref. #11534100]
- Gas PedalSOLD!
