I have an overabundance of M42 parts, honestly, I probably have anything you would ever need. I'd be willing to give some of these parts away, and sell the others. I'd like to sell the big shiny goodies for a reasonable price though, as I am a recently graduated student trying to make some monies.
Many prices are open to negotiation.
Pm me if you need any engine parts, I'll be able to help you out. Stuff I'm officially listing for sale:
Transmission - sold
Cylinder head 60,000 km's e36 head, so it has the 6mm valve stems! - SOLD
Valve cover - 40$
Intake assembly $80
stock injectors $10
many switches (defrost, windows, window pig tails for e36 switches $10
M42 block 60,000 $50
M42 stock internals $50
m42 oil pump gears, and housing both look brand new. $150 for both. These frequently crack...
m42 Lower oil pan $50
Power steering pump $50
Alternator $50
E36 m42 oil pan (1 piece pan) $50
E30 Rad support, OEM, brand new $150.
4 piston Mazda calipers. Includes 1 bracket made to the correct offset and spacing to adapt the caliper to the e30 front brakes. I have fittings for these as well. You will need to take this piece to get another two machined, should be pretty cheap. I can send a cad drawing of the bracket as well if that helps. $150 shipped.
E30 abs pump $50
E30 abs computer $50
K&N cone filter $50
Cool stuff.
Lowest advertised price, If its in my signature it's on special.
4,10 lsd small case. needs a new bearing on one of the axle output shafts. $150
Nice set of smilies, $240 SOLD!
Another set of smilies $220 shipped. SOLD!
1 more set of smilies, this set is in decent condition. Needs a new housing as one of the adjuster mounting pieces is broken. $100 SOLD
M42 turbo kit, - $2,125 Shipped
4 piston Mazda calipers. Includes 1 bracket made to the correct offset and spacing to adapt the caliper to the e30 front brakes. I have fittings for these as well. You will need to take this piece to get another two machined, should be pretty cheap. I can send a cad drawing of the bracket as well if that helps. $220 shipped.
M47 Crankshaft - SOLD!
AKG rear subframe bushings - SOLD
AKG rear trailing arm bushings -SOLD
Aluminum rear diff bushings -$60 shipped
EBC Green stuff pads - $75 shipped per set. front and rear set available
MONO Wiper conversion kit $220 shipped
Early Style RD rear valence and side skirts SOLD
Transmission - sold
Valve cover - 40$
Intake assembly $80
stock injectors $10
Alternator $50
E30 abs pump $50
K&N cone filter $50
Cool stuff.
