FS (RI): M42 Needs maintenance, good compression, local pickup - $100
    I'm hoping to have for sale soon an M42 out of a 91 318i. It has 206k on the clock and needs new guide rails for the timing chain. The valve cover gasket must be replaced as well as it leaks a bit of oil into the spark plug tubes.
    Compression numbers where cylinder 1 is most forward on the engine
    #1) 210 psi and holds
    #2) 200 psi but dropped to 195 psi and holds
    #3) 200 psi holds
    #4) 210 psi but dropped to 206 psi and holds
    The motor runs rough due to a suspected vacuum leak.
    Asking $100 for the motor, wiring, DME
    Time-frame about two weeks. Local pickup only.
    Originally posted by FredK
    However, in your absence, I will likely sit in your seat buck naked while making racecar noises as if I were maxing your E30 out on the Mulsanne Straight while allowing the perforated vinyl to soak up my butt sweat (going 200 mph does that to you).
    My year in Germany
    Feedback
    no interest?
    i'll just make it into a coffee table then.
    My year in Germany
    Feedback
      willing to part out...?? if so If like to buy
      Turbo M42 Build Thread :Here
      Ig:ryno_pzk
      I like the tuna here.
      Originally posted by lambo
        prefer to sell it whole, but if no one is biting the theres no sense in not parting if you need a particular item.
        what did you have in mind?
        (hasn't been pulled yet but just gathering interest for now)
        My year in Germany
        Feedback
          I could really use the upper and lower intake manifold.
          Ig:ryno_pzk
            what is your time table? If someone comes along and wants the motor, I might give them priority because it would save me the hassle of splitting/storing/shipping, but if we can figure out a shipping arrangement (and i find a big enough box) i'll be glad to send it your way given enough time and not a high priority
            My year in Germany
            Feedback
              you want something like this?
              what you did to this car is like getting a supermodel naked and willing to do anything you please. now here you are faced with ths once in a lifetime opportunity and then you squander it by making her fuck you in the butt with a 24" strap on. you are a sad, silly little boy.
                Thats much cleaner than this motor and on west coast too!
                But if cost is factor i'm sure we can figure something out as i'm practically giving this motor away.
                My year in Germany
                Feedback
                  yea minus throttle body... how much
                  Ig:ryno_pzk
                    Hey man, I'll pick it up for $100 when it's out.
                    And DJ Buttchug you have a gross name but I have an M42 with a hole in the block that i'm about ready to part out so let me know what you need via PM and I'll tell you what I can do for it.
                      perfect!
                      My year in Germany
                      Feedback
                        Motor + wiring + dme is coming out this weekend (i need to keep the DME bracket..and am reusing the g240)
                        just a heads up if you are still interested Mossman
                        My year in Germany
                        Feedback
