Hey guys. I'm cleaning all of the odd-ball BMW parts out of my garage to make some more room for cars. These are parts from an S50B32 I took apart after it was hurt at the track. The engine had 70k miles on it with a season or two of DE duty. If the components are damaged, there will be details about that in addition to the photos you can see below.
All of these prices are OBO. I would really like to make some room in my garage, so don't be shy with offers.
Cylinder Head; $250 shipped--
The piston in cylinder three turned into a bunch of chunks of metal about the diameter of a quarter. As a result, there was damage to the combustion chamber and valves in that cylinder. There may be damage to valve seating areas on other cylinders as well as a result of the metal from the piston that was pushed through the intake into other cylinders. I have seen worse damage in a cylinder head that was repaired, but I would certainly go through the whole unit. The cap for lifter number 2 on cylinder 3 is stuck in it's bore (pictured) in the cam tray. I could probably tap it out easily and inspect the damage to the bore there as well. The cam tray's journals are all in great shape. The pictures should demonstrate how clean everything is.
Cams; $175 shipped --
The cam lobe for valve number 2 on cylinder 3 has damage on it's nose. There is an indention towards the side of the lobe where it contacted the lifter after it became stuck in it's bore. The oiled surfaces are in excellent condition; matching the condition of the journals and cam bearing caps. These would be excellent candidates for re-grinding to a new spec. You may be able to run it as it is, though I couldn't necessarily recommend that.
The damaged lobe-
Other lobes and bearings (showing condition)-
Complete head assembly; $400 shipped--
Valve cover and coil cover; $115 shipped--
A couple of scuffs-
Balancer; $25 shipped w/ 4 Torx bolts and plate + chain tensioner; $50 shipped--
This chain tensioner works with US engines as well and is a nice upgrade for the S14.
Waterpump, thermostat, and t-stat housing; $150 shipped + Crank and Water pump pulleys; $15 shipped each--
S50B32 Alternator (may work for other applications as well); $120 shipped--
^^The 2002 Euro turn signals will be availible shortly if anyone here is into those.. I've also got a set of rare OEM clear Euro turn signal lights from a very early car.
I also have other S50B32 parts so let me know if there is anything that isn't listed that you are looking for.
For M20/non-swapped guys, I have a few items as well. Some are just general E30 stuff.
Late model knee bolster; $30 shipped--
All of the mounting points are intact. There are some scuffs on the exposed side of the piece, but overall it is in good shape.
Porterfield Racing Brake Pads, front, new; $50 shipped (Sold)--
These are great pads for racing, track days, or really spirited driving. They cost $110. I just don't need them in inventory since I have no 4-lug cars.
2 of 4 pads-
Alternator; $40 shipped + starter; $30 shipped + and power steering pump; $30 shipped--
These are from my '87 325es. That car had a broken odometer with 193k on it, so these are from a 200k car. Not sure if/when they were replaced, but they all functioned well for 2 years until I swapped in a bigger engine.
Genuine 24k Gold-Plated Kidney Grill from the 80's; $30 shipped (Sold)--
I'm selling this for the owner, who is in jail. It is showing some signs of age- the plating is thin and some silver is evident along the edge that faces fowards (in second picture).
Adds +2 cool points on the street, +3 cool points and +1 hp at a DE, or +5 cool points and +2 hp at a race event.
Cheers,
Ryan
The damaged lobe-
A couple of scuffs-
2 of 4 pads-
Cheers,
Ryan
