I just moved from MO to SoCal and pretty much brought my garage with me. I don't really have the space or time to continue my project so it's all for sale. I'm more interested in getting rid of this stuff than making a profit, I think my prices are pretty low but everything is OBO anyways. The items and myself are located in the southbay area for the locals.
There are a lot of parts and I haven't listed some of the smaller ones. PM me if you're looking for something specific e.g. M20 block oil pressure relief valve or an oil switch or something.
The stuff:
* 2 M20 blocks$100.00 each
* 2 M20 cast aluminum oil pans $50.00 each
- Block 1 M20B25
- Has B25 crank, piston and rods removed after this happened, block should be ok with standard engine prep.
- O-ringed
- Block 2 M20B25
- Still has internals, completely stock. New timing belt pulley
* New Valve stem seals, at least enough for 1 head $ 3.00
* 4 stock M20 rocker shafts $5.00 each
* i intake manifold powder coated grey $60.00
* Stock E30 fuel rail $10 .00
* New-ish stock pressure regulator $15.00
* 6 new bosch 19# injectors $ 100.00
* Stock E34 fuel rail $10.00 SOLD
* Stock fuel pressure regulator $10.00 SOLD
* 6 stock 15# injectors used $50.00 SOLD
* 325i throttle body with stock tps $10.00 SOLD
* 2 M20 valve covers with oil caps $20.00 each
* 1/2 tube of unirex grease, you use it on the tranny splines during installation. 83239416138 $3.00
* 1 M20 Oil Sprayer bar $ 4.00
* 1 Stock M20 crankcase ventilation tube $ 2.00
* 2 e30 oil filter adapters with thermostats $ 5.00 SOLD
* 2 M20 oil pumps $ 30.00
* 3 M20 cooling fans $ 5.00 each
* 2 M20 fan clutches $ 6.00 each
* The white box contains 6 36# bosch injectors, they need to be remanufactured or cleaned. $ 10.00 SOLD
* 2 oil drain tubes with springs and washer, I also have two new o-rings for these $ 3.00 SOLD
* Set of M20 cyl head, headbolt washers $ 3.00
* 3 VR sensors
- The metal one should work $ 20.00
- One has nicked shielding $ 5.00
- One of the plastic ones may have been contaminated with coolant $0.50
* E30 Alternator bracket $ .50
* Bag of rocker retaining clips, should be enough for 1 cyl head in there $ 2.00
* new camshaft oil seal $ 1.00
* new cyl head rear coolant line gasket $ 1.00
* 2 used M20 starters, both are working $ 15.00 SOLD each
* E34 windshield washer reservoir with level sender $ 3.00
* 2 M20 stock cam gear $ 1.00 SOLD each
* 1 m20 oil pump gear / pulley $ 1.00 SOLD
* 2 M20 thermostat housings $ 3.00 SOLD
* 1 M20 harmonic balancers $ 3.00
* 1 M20 main pulleys $ 3.00
* 1 M20 water pump pulley $ 1.00 SOLD
* 2 M20 upper timing belt cover $ 5.00
* 2 M20 Lower timing belt cover $ 2.00
* 3 M20 rubber side cover for timing belt $ 1.00 each
* 1 bag, all transmission mounting bolts $ 1.00
* Box of misc M20 bolts, intake, oil pan, etc $ 1.00
* 7 Cylinder head rocker shaft plugs $ 0.15 each
* New M20 timing belt SOLD
* E30 engine harness $ 5.00
* Misc Hoses and clamps $ 1.00 each
* 2.5in Silicon Hose couplers $ 1.00 each
* 2.5in intake pipe from bay turbo piping kit, painted black, misc bends $ 1.00 each
* 2 Idle air control valves $ 5.00 SOLD each
* 2 Power steering pumps $ 15.00 each
* 1 E30 90 degree intake boot $ 5.00
* 1 2.5in to 2.0in 45 degree silicon reducer, never used $ 10.00
* 1 E30 alternator $ 30.00 SOLD
* misc brackets switches covers etc $ 1.00 each
* 1 I intake manifold $ 30.00
Return policy: I'm not really interested in being a douche or scamming people so if you pick it up locally and aren't happy with it I'll refund your cash. If it's shipped and not satisfactory you'll have to ship it back and I will refund you.
The stuff:
- Block 1 M20B25
- O-ringed
- Block 2 M20B25
* 3 VR sensors
