Garage clean out
  • Tony
    • 92
    Garage clean out
    I'm cleanig out the garage. With prices are the parts with the most value the other stuff is just spare parts. The Cobra seat I used in my E36 M3 for track days and has very little use, there is no wear on the seat. I also have seat mounts to put this into an E30.
    The wheel bearing tool was purchased new from Pelican parts and used once. It makes wheel bearing changes very quick and easy.
    The Spal fan is new, I never got around to converting my e30 to it.
    Same as with the camber plates, they are new, you can look on IE web site for detailed description.
    THe S52 crank is great for those wanting to build that 3.1L M20.
    What I would like to do is sell this as one big lump to move it out and make space. THere is close to $1400 in parts here, so I would like to get $1000 out of and not have to part it out. So if you have any questions please PM me, and make an offer.
    Link to pics, https://picasaweb.google.com/1011577...IeqgMj73PPWTg#
    Cheers
    $100 new Brey Krause E30 seat mounts
    $600 new + mounts $100 new Cobra Imola II racing seat with Brey Krause e36 mounts
    $300 new BMW e30 e36 and others, wheel bearing tool
    $80 new Spal 10” fan new in box
    $275 new Ireland Engineering street track camber plate system new
    $300 S52 crank shaft, to make a 3.1L m20
    $40 each New in box clutch master cylinder and slave cylinder
    325 steering rack
    E30 power steering pump, needs rebuilt
    Extra half shaft
    Red BMW m20 valve cover, and new gasket
    E30 top spring hats, e30 abs sensors
    Assorted hose and ducting
    Assorted hoses, new throttle cables, m3 oil/air separator, new crossover tube
    325 throttle body and hoses
    Bosch 153 DME
    Stock shifter
    Assorted suspension links and bushings
    E30 tail light seals, extra O2 sensor new, Koni bushings,
    Rubber spring pads, to adjust rear suspension height, old shifter assorted nuts and bolts
    E30 fuel filter new in box, 3 new oil filters, extra Hawk brake pads
  • E30 331is
    • Sep 2011
    • 1166
    link no bueno
    • Tony
      • 92
      Try it now
      • Tismael711
        • 791
        You have a PM on brake master cylinder
        • m20wannabe
          • Mar 2012
          • 7
          throttle body
          If you still have the throttle body
          Could you send pics to anderscam@hotmail.com
          • Vspec
            • Jan 2005
            • 114
            Ford 3 wires O2 sensor?
            01/88 325is re-assembly required - Garage recluse - Parts pile growing
            • E30 331is
              • Sep 2011
              • 1166
              Clutch master & slave available?
              • cyrmanj
                • Oct 2007
                • 251
                PM sent regarding ABS sensors, thx.
                e30 diamantschwarz 325i
                http://www.flickr.com/photos/cyrmanj/
                • downforce22
                  • Aug 2009
                  • 3189
                  do you have the oil seal for the crank to make it work in the m20?
                  Harmonic balancer assembly/ hub?
