Steering Column Tilt kit
  • davem
    • Jun 2010
    • 705
    Originally posted by Mark 42
    t sounds like maybe they are completely blank?
    yup impossible to remove with tools
    • Mark 42
      • Apr 2012
      • 291
      Not even enough there for vice grips?
      I'll see if I can cut a slot with a Multifunction Tool, since I also read it's hard to get in there with a dremel or die grinder.
      It sucks that most of my tools are 45 minutes away.
      • SLEEPYDUB
        • 658
        You can't fit vice grips in there. You'll need to either extract the bolt with an extractor or cut the head off with a grinder.
        I explain it all in the instructions included.
        - AXIS POWERS - 2JZ E30 Build
        Current Project - 87 325is 2JZ Swapped with M4 DCT
        • Mark 42
          • Apr 2012
          • 291
          Okay - I have extractors. How hard is the bolt?
          I have left hand drill bits - they are fantastic for getting bolts
          out because usually the will bite into the metal and spin the
          bolt out so that you don't even use the extractor.
          But good ones cost a bit (no pun intended) more than the regular bits, especially
          for single replacement bits, so I don't like to use them on hardened fasteners.
          Luckily I did bring my Taps, Dies, Drills and Extractors out of storage.
          (I need a barn like we had in Alabama)
          • SLEEPYDUB
            • 658
            Seems like that will work just fine.
            Making some more of these today guys, thanks for your patience.
            • Mark 42
              • Apr 2012
              • 291
              I have an idea for an adjustable version, but I haven't looked under there
              to see if it would even be possible.
              The idea is sort of a telescopic mechanism with either a pin through it
              (using a series of holes that line up every 1/2" or so) or a clamp of some kind.
              If you want to take that and develop the idea further, go for it.
              I have a lot more ideas than I have time & space to build.
              • Farbin Kaiber
                Lil' Puppet
                • 29502
                Seems like this should be called a drop kit, as "tilt" means adjustable.
                Originally posted by Steering wheel
                Tilt Wheel
                The original Tilt Wheel was developed by Edward James Lobdell in the early 1900s. The seven position Tilt Wheel was made available in several General Motors products in 1963. Originally a luxury option on cars, the tilt function helps to adjust the steering wheel by moving the wheel through an arc in an up and down motion. Tilt Steering Wheels rely upon a ratchet joint located in the steering column just below the steering wheel. By disengaging the ratchet lock, the wheel can be adjusted upward or downward while the steering column remains stationary below the joint. Some designs place the pivot slightly forward along the column, allowing for a fair amount of vertical movement of the steering wheel with little actual tilt, while other designs place the pivot almost inside the steering wheel, allowing adjustment of the angle of the steering wheel with almost no change it its height.
                • Mark 42
                  • Apr 2012
                  • 291
                  Seems like this should be called a drop kit, as "tilt" means adjustable. :hitler:
                  It is adjustable... by simple changing the spacer blocks. :twisted:
                  • SLEEPYDUB
                    • 658
                    I think you may be right.
                    Sent from my SAMSUNG-SGH-I727 using Tapatalk 2
                    • bigdrick323
                      • Feb 2012
                      • 616
                      Interested, mine is way too high and tilted backwards. Would like it in set position like the full down and forward position position e46.
                      Sent from my HTC One V using Tapatalk 2
                      sigpicMy Project!
                      Official North Texas Bimmers Club E30 Representative
                      www.BimmerAlliance.net
                      "If you have questions about events or need help in the DFW area don't be afraid to contact me."
                      • bigdrick323
                        • Feb 2012
                        • 616
                        Anything more on this?
                        I am away from my computer, being lazy!
                        sigpicMy Project!
                        • bigdrick323
                          • Feb 2012
                          • 616
                          I am still waiting for my kit or a response.......
                          Sent from my LG-MS870 using Tapatalk 2
                          sigpicMy Project!
                          • SLEEPYDUB
                            • 658
                            Rick, I have sent the package to my secretary. It is on its way out in the morning. thank you for your patience.
                            • OGT's e30
                              • Nov 2012
                              • 96
                              You have 1" available?
                              • SLEEPYDUB
                                • 658
                                Yes
