I can clean your fuel injectors. Just pay for shipping and the fluid
    You can order the service here:
    SERVICE TEMPORARY ON HOLD
    I've been working for Bosch than Volvo and BMW in Europe and used to do this as a novice when i was in training for BOSCH.
    I remember the difference a clean injector makes in the way the car runs and how often i used to see them in poor condition.
    High Performance NEW Injectors Here:
    Black Mamba 850 cc/min 80lb Injectors
    Black Racer 650 cc/min 60lb Injectors
    Rough Green 440 cc/min 40lb Injectors
    I'm in Southern California by the way. About 1 hour from LA
    Compatibility:
    BMW cars from mid 80s to early 00s
    4 Cylinder M40 M43 N42 S14
    6 Cylinder M20 M30 M50 M52 M54/M56 N52 S38 S50 S52 S54
    8 Cylinder M60 M62 N62 S62
    12 Cylinder M70 M73 S70
    International Shipping Available
    25$ Ships Anywhere in the World
    Order instructions:
    - After the order is paid (paypal invoice/ebay listing), you will receive an email with Shipping Instructions (address at the bottom of the listing as well)
    Ship your injectors to the address provided. USPS Flat Rate Priority Mail works best @ ~6$ (50$ insurance included + tracking)
    Use tracking info on all your packages and Insure all injectors worth more than 100$
    - I only ship back on Mondays. Please take that into consideration when sending in your injectors or placing an order
    - Once your set is ready, you will receive a picture with the test results - Before/After the service.
    - There're cases when injectors fail or are beyond repairable condition. Please expect delays in these cases.
    I have replacements for most of the engines specified in the Compatibility list above, but stock is moving fast at this rate.
    Please note !
    Service does not include Painting the injector or external rust prevention.
    This is an extra option and it will cost you an extra 1.99/each. I will remove the rust and apply a clear coat.
    10-Step Rebuild Process - Full Service
    1. Initial Visual Inspection - Check the injectors for signs of physical damage.
    2. Impedance Testing by checking the resistance of the coil.
    3. External Degrease Soak - Soak them in a degreaser solution
    4.External cleaning - Brush off the loosened grime from the injectors
    5: De-filtering - Remove the old filters in preparation for ultrasonic cleaning.
    6. Ultrasonic cleaning - The Injectors are soaked in Degreaser and Left pulsating in the Ultrasound Bath
    7. Purge the injectors - Install the injectors on the Fuel rail and spray into containers to ensure none of the fluid we use in the ultrasonic cleaner gets put into the calibration fluid.
    8. Flow Testing - Flow through the machine checking for spray pattern and any signs of malfunction at different RPMs and PSIs
    9. Filter Basket installation - Install the new filters.
    10. Reassemble - Using all new applicable parts (O-rings, spacers, pintle caps)
    If you care to see how specific injectors were performing, you need to mark each of them with the Cylinder number and i will make sure i keep those numbers for your record.
    Please note you forum ID on the package to help me keep track of communication.
    This is a nice article on how to remove your injectors with pictures. Applicable for the E36 engines but process is similar on most of the cars
    http://www.pelicanparts.com/bmw/tech...eplacement.htm
    Here's the process similar to what I do.
    Here's a good table to give you an idea of compatibility
    http://www.mepeh.com/injector-flow-rates/
    Facebook is the best way to reach me while i'm out
    https://www.facebook.com/MEPEHinjectors
    About My Refurbished Fuel Injectors
    A fuel injector sprays fuel directly into your engine's combustion chamber in a very fine mist to ensure optimum combustion performance. Sometimes it is difficult to determine if an injector needs to be replaced or just cleaned which is why you often use fuel additives to clean injectors prior to replacing them. Cleaning additives will normally get stuck in the filter, that's why a more delicate process is required.
    All my injectors are carefully picked from freshly junked cars and normally still have fresh fuel in them. My refurbishing process will ensure you'll have one (or a set) of injectors that is perfectly matched within 2% of the Manufacturer Specified Values. I will install New O-rings, spacers and Pintle Caps. Basically all serviceable parts will be replaced with brand new ones.
    Get your Injectors Cleaned HERE
    I am interested in this. PM sent
      LINKS
      Blue top M20 Injectors 0280150715 HERE
      Green top M50 Injectors 0280150415 HERE
      Pink top M52 Injectors 0280150440 HERE
        Here's an example with the 0280 150 126 ETA Injectors
        http://www.r3vlimited.com/board/show...&postcount=105
          I already sent my set your way!
            Sounds good.. I'll update you once I get them
              Dammit! I just paid someone to do mine like a couple weeks ago. Good on you man.
              Your resource to do-it-yourself and interesting bmw and e30 stuff: www.rtsauto.com
              Your resource to tools and tips: www.rtstools.com
                If you have spares, could you sell me a complete set for an M20B25? Only extras I have are super eta, can't put my DD down for the turnaround time.
                Don't buy an e30
                They're stupid
                1989 325is Raged on then sold.
                1988 325 SETA 2DR Beaten to death, then parted.
                1988 325 SETA 4DR Parted.
                1990 325i Cabrio Daily'd, then stored 2 yrs ago.
                  Give the part numbers for the ones you need. Wish I could remember what each engine used.
                  Plus, I have about 200 injectors and they are all in one big box.
                  Not sure if I have yours in stock. I may get some this weekend for your car if I hear back from you today
                  Edit: I can get yours this weekend.
                  It will be 10 $ per injector. Cleaned, tested and shipped to you in a priority mail box.
                    PM'd
                    Don't buy an e30
                    They're stupid
                      Replied
                        where are you located?
                          If you have a second set of 6 for an M20B25, I would like a set. I am building a race car, and I figure when I tear into the engine I will swap the rebuilt injectors in there, at which point I'll get the old ones rebuilt to keep as spares.
                          Thanks for doing this -- very generous.
                            Mentioned in the first post
                              thanks for helping out the community.
