Everything is obo. the things I would be willing to trade for are, IX booster, coil overs, rims or anything interesting. willing to put cash on top.
Not pictured. red label 413 for 24v swap. 75 shipped
fk springs 60/40mm drop. 325lbs if i remeber correctly. about 8k on them 180 obo
15in bbs ra's, in decent condition one was repaired. pictured. good tires 350. et32 6.5in wide
rim 1
rim 2
rim 3
rim 4
repair
miller maf conversion with the chip. set up for 19lb injectors can include injectors for a little more. for m20 173 ecu 150 (SOLD)
dinan chip for 173. 15 hp 15 tq and raised the limiter a little bit. youll needed to run 91 with this. 60
M20 ebay headers, 60 (SOLD)
ansa muffler for m20 direct bolt on. 5kish on it. 120 obo
173 ecu 50. late model coil 20. 122k on it. AGK motor mounts 5k> on them 75d compound. 40
First up 4.10 open diff. 122k on it. 60 obo
came off of a s50. its the bracket that holds the ac pump to the block. 15? no idea what its worth
late model auxiliary fan. 40
m20 stock exhaust manifolds 15
top is stock m20 injectors about 100k on them. will rebuild upon request. bottom is ford 19lb injectors unknown mileage. worked fine when they were pulled. will rebuild upon request for cheap. 5 a piece.
stock late model air box 15. PS res 10. master cylinder and res 122k 25. fuel rail 122k 10.
auto trans brace 5. auto airbag pedal box with auto break pedal 40. non air bag manual pedal box 20. radiator hold down 5. auto selector and cover 15. break booster 122k on it 50.
AC piping 10. AC cooler 15. fan clutch maybe 2 years old 25
rim 1
rim 2
rim 3
rim 4
repair
