prices do not include shipping.
A/C switch, $ 10
Ashtray, front, $ 9
Ashtray, rear, $ 17
Audio, Stinger power distribution block, used for a week, 3 out of 4 fuses included, Digital Voltage read out, LED warning, Audible fuse warnings, 2 inputs, 4 outputs, had to upgrade to amps/volts unit, $ 35
Balance switch, $ 5
Bumper side markers, pre or post bumpers, front or rear, $ 7ea
Cabrio bottom rear seat, black, leather, $ 80
Cabrio / M3 front seats, black, leather, driverside it's heated,
passanger side needs restiching in upper outer bolster and loweer inner bolster., driverside will go with extra oem replacement pieces for 2 out of 3 ripped areas, may be able to find 3rd piece. $ 250
Central lock module, # 323 or 302, $ 35
http://www.freakyfranky.net/ebaystuf...rallock323.jpg
Check panel , non SRS, $ 9
http://www.freakyfranky.net/ebaystuf.../checke302.jpg
Coolant gauge, VDO or MotorMeter, % 15
http://www.freakyfranky.net/ebaystuf...ugecoolant.jpg
Cruise Control system, auto or manual compatible, $ 100
http://www.freakyfranky.net/ebaystuf...uisesystem.JPG
C/C actuator $ 40
Cruise Control Switch, $ 15
http://www.freakyfranky.net/ebaystuf...iseswlong1.jpg
http://www.freakyfranky.net/ebaystuf...iseswshort.jpg
C/C Clutch pedal switch, $ 7
C/C green plug for gauge cluster, $ 7
C/C harness, $ 35
C/C module $ 30
http://www.freakyfranky.net/ebaystuf...isemodule2.jpg
Defroster switch, green or amber, $ 7
Dome light relay with timer, $ 25
http://www.freakyfranky.net/ebaystuf...aydelay974.jpg
http://www.freakyfranky.net/ebaystuf...aydelay975.jpg
Dome light switch, $ 7
http://www.freakyfranky.net/ebaystuf...htandswe30.jpg
Door handle, inner, pasanger side, $ 7
Door handle, inner, driver side, $ 7
ECU, 318i M40, euro model, # 157, $ 75
Eibach ProKit springs, 325 type, (not iX/iC) compatible, 2 sets available, $ 150 each.
Fan blower switch, 3 or 4 speeds, $ 7
Fog light switch, $ 5
Fog lights, late style, $ 40 each
Fog lights, early style, $ 35 ea
Fog lights, yellow, I used them as French style headlights, $ 50 a pair.
Fuel gauge, VDO or MotorMeter, $ 15
Hood release handle and cable, $ 15
Gauges and pod, VDO, no drilling require, including 2 prong presure sender for gauge cluster idiot light to work as it should. 16 Volts, Oil temp and Oil Pressure. you'll need an adaptor from BMPD to install pressure sender $ 35 and a temp sender $ 20, I can include a temp sender but it will be too small for oil drain plug hole. $ 100
Gauge cluster cover, upper, $ 9
Gauge cluster cover, lower, $ 9
Gauge clusters, empty, $ 10
Gauge cluster light bulb set, $ 15
Glove box latch, inner, $ 7
Glove box latch, outer, $ 7
Hazard switch, $ 7
Heater control knob set, $ 7
Kickpanels, black or beige, $ 25
Knee bolster, underdash cover (non ABS) $ 30 each
Power mirror switch, $ 7
Power window front lock switch, $ 7
Power window rear lock switch, $ 5
Power window switch, illuminated 1 = $7, 2 = $13, 3 = $19, 4 = $25, 5 = $31, 6 = $37 & 7 = $43
OBC system with correct code plug, inner and outer harness, etc, $ 150
OBC with 3.8, 3.12 or 4.6 code plug and working light bar, $ 35
OBC compatible turn light switch, $ 25
OBC ambient Temp sensor, $ 20
OBC compatible door gong/chime, $ 7
OBC under dash harness, 10 (pre 89) or 7 (post 89) plugs, $ 30
OBC under dash hood harness, $ 35
OBC control module, $ 20
OBC compatible horn and bracket $ 15
Rear head rest brackets, $ 40 a pair
(can get you any color, finish headrests for another $ 40)
Relay set, $ 20
http://www.freakyfranky.net/ebaystuf...etfusebox1.jpg
Seat belt, driver side, $ 20
Seat belt, pasanger side, $ 15
S.I. boards, big or samll batt type, code or non code plug type, $ 35
http://www.freakyfranky.net/ebaystuf...1/siboard1.jpg
Sport iS early front spoiler for big bumpers, $ 90
http://www.freakyfranky.net/bmwstuff...f/108_0813.JPG
Sunvisors, $ 20
http://www.freakyfranky.net/ebaystuf.../sunvisors.jpg
Swaybars from a cabrio, front and rear, about as big as Eibach and other tuners.
think I have a set of urethane bushings for them, will have to look for them. $ 125 a set,
Tach, VDO or MotorMeter, 7k, $ 25
http://www.freakyfranky.net/ebaystuf.../tach7000.jpeg
Tail lights, Late style, L or Right side with back covers, $ 35 ea.
Turn light relay, $ 9
http://www.freakyfranky.net/ebaystuf...3113670012.jpg
Turn light switch, $ 15
http://www.freakyfranky.net/ebaystuf...tur%20e301.jpg
Wiper relay, $ 9
http://www.freakyfranky.net/ebaystuf...iperrelay1.jpg
Wiper Switch, $ 15
http://www.freakyfranky.net/ebaystuf...s/wipersw1.jpg
http://www.freakyfranky.net/ebaystuf...s/wipersw3.jpg
and a whole bunch of other parts that forgot to include.
also some mountain bike and road parts, including brand new forks, nite rider lights, Bolle sunglasses, smiths lenses, thomson seat post, etc...
A/C switch, $ 10
Ashtray, front, $ 9
Ashtray, rear, $ 17
Balance switch, $ 5
C/C actuator $ 40
C/C harness, $ 35
C/C module $ 30
Hazard switch, $ 7
Relay set, $ 20
Sunvisors, $ 20
Wiper relay, $ 9
Wiper Switch, $ 15
