I will ship to anywhere in the USA if you pay for the shipping. All items are located at the Revshift shop in Warren, MI. I can take paypal, a credit card over the phone, or a check/money order in the mail. I am the owner of Revshift and all of the money from these parts is going back to the company. We are a trusted vendor on the forums so there is no need to be skeptical about paying us.
If you are interested in any of these items or if you have questions PM me or call me at 586-510-4042 (Revshift shop) and ask for John.
885 Head:
- new +1 intake valves
- new valve seals
- new valve guides
- welded water jackets
- freshly machined, milled, valve seats
- clean oem cam
- new oem rockers
- new cam seals
- new valve springs
$800
SOLD Intercooler and piping:
- Bar and plate intercooler
- no leaks
- includes two Mode bypass valves
- steel piping, fully welded, no mid couplers.
- included 90 degree coupler and v-band flange for HX35 turbo
- includes intake air temp sensor
- custom made for an E30 with top mount turbo
SOLD $250
SOLD M20 Oil Pan
- turbo oil return fitting installed (welded and coated with JB weld)
- no cracks
- baffles and level sensor included
- oily
SOLD $80
(SOLD) M20 Short Block: (SOLD)
- freshly machined block, decked, bored, honed. It has been o-ringed for boost.
- Custom JE pistons, 85mm, forged. They are somewhere in the 8.5-9.0:1 compression range, its built for boost.
- Eagle H-beam S52 rods, forged
- freshly machined oem crank
- new bearings and piston rings
- new freeze plugs
- ARP head studs
- ARP main studs
- ARP rod bolts
- Race ready!
$1,500
http://www.revshift.com/e30parts/e30block2.jpg
http://www.revshift.com/e30parts/e30block3.jpg
http://www.revshift.com/e30parts/e30block4.jpg
http://www.revshift.com/e30parts/e30block5.jpg
http://www.revshift.com/e30parts/e30block6.jpg
(SOLD) Holset HX35W Turbo: (SOLD)
- Customized for an E30
- black ceramic coated exhaust housing
- welded v-band exhaust outlet (will never leak)
- twin scroll T3
This HX35 is in excellent condition. No excessive shaft play. Ceramic coated exhaust housing. Compressor housing is painted black with high temp paint. The exhaust outlet flange was bolted to the turbo and then tig welded all the way around. There is no possible way to have any exhaust leaks with this turbo. The v-band outlet was made to with with the E30 downpipe that I am selling and vice versa.
$450
http://www.revshift.com/e30parts/e30holset1.jpg
http://www.revshift.com/e30parts/e30holset2.JPG
http://www.revshift.com/e30parts/e30holset3.JPG
http://www.revshift.com/e30parts/e30holset4.jpg
http://www.revshift.com/e30parts/e30holset5.jpg
http://www.revshift.com/e30parts/e30holset6.JPG
(SOLD) MegaSquirt-III V3.0 ECU: (SOLD)
- Assembled
- MS3 daughterboard
- MS3X expansion card
- brushed aluminum case mounted to oem E30 bracket
- mess of wiring included
$300
http://www.revshift.com/e30parts/e30ms31.jpg
http://www.revshift.com/e30parts/e30ms32.jpg
http://www.revshift.com/e30parts/e30ms33.jpg
http://www.revshift.com/e30parts/e30ms34.jpg
http://www.revshift.com/e30parts/e30ms35.jpg
(SOLD) E30 Turbo 2.5" Downpipe (SOLD)
- Wrapped with header wrap
- V-band on both ends
- wideband o2 included
$80
http://www.revshift.com/e30parts/e30downpipe.JPG
(SOLD) M20 Valve Cover with Coils (SOLD)
Six ignition coils are mounted to the valve cover to be used with MegaSquirt-III. Plug wires included as well as a mess of wiring.
$150
http://www.revshift.com/e30parts/e30valvecovercoils.jpg
(SOLD) M20 Ishihara-Johnson Crank Scraper (SOLD)
- new
- steel
$60
http://www.revshift.com/e30parts/e30crankscraper.jpg
885 Head:
- new valve seals
- new valve guides
- clean oem cam
- new oem rockers
- new cam seals
- new valve springs
$800
- no leaks
SOLD $250
SOLD M20 Oil Pan
- no cracks
- oily
SOLD $80
- new freeze plugs
- ARP head studs
- ARP main studs
- ARP rod bolts
- Race ready!
$1,500
- twin scroll T3
$450
- Assembled
- MS3 daughterboard
$300
$80
$150
- new
- steel
$60
