Please buy my parts. I'm a hoarder. Located in Victorville, CA. I will ship the smaller stuff if necessary.
HOWEVER, if you want to start a hoard of your own, You can have the entire thread for $300 (There's over $700 of stuff here added up)
My paypal is joemadoo@gmail.com
M20 "i" parts (m20b25)
Starting from the top-left:
Upper timing cover $4
lower timing cover $3
tranny spacer thing $3
"i" cooling hose arrangement (5 hoses there) $10
idler gear $5
oil pump (needs to be cleaned) $10
tensioner arm and pulley $5
water pump $10
coolant spout $3
water pump pulley $4
oil vent tube + spring $5
plastic dist. cover $3
intake bracket $3
coolant housing SOLD hose available $5
cap + cover $7,
PS pump + bracket $18 SOLD
alternator + adjuster $18 pending
plastic cover $2
M20 "e" valve cover $10
"i" intake manifold $30
I have all the i/m brackets and hardware as well.
M30 valve cover (clean) $15
M50 plastic cover $7
"e" Black valve cover $12
Random lot:
CV axles (boots torn but working condition) $20 for both
m20 fan $10
e30 transmission crossmember SOLD
e30 5 speed early style shifter, plate, and lower shift arm SOLD
m30 afm bracket $4
e30 driveshaft dampener $5
e30 licence plate bracket $4
m20 coolant spout and sensors $6
m30b35 exhaust manifolds (broken studs) $8
e30 rear hubs $9 each
e30 front plastic bumper shocks $24 for the set PENDING SALE
Random lot:
M30 intake boots $4 each
e30 shock mount $5
M30 "004" afm SOLD
diving board shock $6
crank pulley $4
m20 engine mount bracket + rubber $15 for the set
m20 "e" exhaust manifolds $12
e30 325es stock springs $30 for all 4
various rubber spring spacers $1 each
Bumpers:
e30 front diving board with strips and shocks $15
e30 rear plastic with strips SOLD
e30 front red plastic (damaged) SOLD
e30 front sanded plastic SOLD
"es" front spoiler (broken tabs) $15
Fog lights are SOLD
Sway bars:
18mm w/ links $15 each
21mm SOLD
E30 control arms (boots are busted) $15 for both
Z3 6cyl trailing arm $10
e36 knuckles and hubs $10 each
E36 front calipers and brackets $35 for pair
E30 rear calipers and brackets $25 for pair (33mm piston)
E36 rear calipers $30 for pair (36mm piston)
front plastic lower grill for late model valence (one side has broken tabs) $6
washer fluid tank $8
e-fan $20
upper glove box cover $7
side glove box cover $5
Pipes:
3"x 36" aluminum pipe (new and still somewhat wrapped) $20
2.5" x 18" straight $8
2.5" 90deg $10
2.5" u-bend $10
3" to dual adapter 1.75"? (top) $15
m102 turbo downpipe clusterfuck $10
idler gear $5
water pump $10
coolant spout $3
intake bracket $3
cap + cover $7,
plastic cover $2
Random lot:
m20 fan $10
m30 afm bracket $4
Random lot:
e30 shock mount $5
M30 "004" afm SOLD
crank pulley $4
Bumpers:
Fog lights are SOLD
Sway bars:
21mm SOLD
e-fan $20
Pipes:
2.5" 90deg $10
2.5" u-bend $10
