FS/Feeler: M20 turn key turbo kit
  • 2.5-12
    • Jan 2010
    • 1814
    hey guys -- I an posting this more to gauge out what it's worth as I decide the future of my beater rally machine.
    this turbo setup is mainly based on an eBay clone of a Garrett T04E Vband internal gate turbo. runs a CX racign rev2 manifold, eBay charge piping, intercooler.
    engine management (included) is a Megasquirt Microsquirt V3 spliced into a factory Motronic 1.1 89 325i harness. has an added external IAT, deleted spark plug pickup and oxygen sensor. I ran this harness spliced directly into the chassis wiring (no C101, but the wire colors are all unchanged from factory, so a C101 could easily be reinstalled.
    setup comes with:
    * T04E clone turbo, I've put 4000 miles on this charger, half of that was a road rally. holding up very well.
    * Megasquirt Microsquirt engine computer and attached engine harness Plug N play. includes harmonic balancer, trigger pickup bracket and CPS as well as all other sensors needed to convert an older Motronic 1.0 car if needed. includes GM 3 bar MAP sensor
    * 42lb green giant fuel injectors, with fuel rail and regulator
    * all charge piping, joiners, intercooler
    * ss turbo manifold CX racing rev 2 (clears oil cooler and filter on iX and RWD)
    * oil feed and drain lines for turbo
    * sandwich plate for oil feed
    * M12x1.5 to 1/8" NPT fitting for oil turbo feed
    * complete throttle body (M50 TPS)
    * blow off valve and vacuum lines
    * RS232 tuning cable for the Microsquirt (not USB, sorry guys)
    * v band downpipe wrapped with heat tape. comes with two Vband clamps.
    * sweet air inlet system with K&N filter.
    computer has a fairly conservative but safe tune on it. no idle valve, so idle is regulated with the screw on the inlet manifold. I typically get a very low idle around 30 degrees ext temp and 1500-1600rpm idle when fully warm. Microsquirt has the provision to drive an idle valve should you want to retrofit.
    I really don't know what to even attach a value at. it's definitely a 'dirty' looking kit, but it makes great power and is complete. $1700 plus ship would likely purchase the entire setup.
    currently set at 11psi boost. I have been caning it on a stock long block and clutch for the past couple thousand miles and it has been rock solid.
    made 226AWHP and 266AWTQ through balloon snow tires on my worn out iX.
    Last edited by 2.5-12; 07-11-2016, 09:01 AM. Reason: updated pricing and components
    1991 E30 M3 Brilliant/black - S54B32/5M
    1990 E30 318iT RHD Lagunagrun/tan - S52B32Turbo/5M
    2011 E82 1M VO/blk/6M
    1991 E31 850i red/grey/6M
    1997 F355 spider red/tan/6M
  • 2.5-12
    • Jan 2010
    • 1814
    bump
    • 2.5-12
      • Jan 2010
      • 1814
      tew thee tawp!
      • 2.5-12
        • Jan 2010
        • 1814
        request daily bump
        • 2.5-12
          • Jan 2010
          • 1814
          double your wtq! bump!
          • 2.5-12
            • Jan 2010
            • 1814
            still boosting around like a champ! BUMP!
            • 2.5-12
              • Jan 2010
              • 1814
              bump! went ice racing with the beast on monday night, didn't skip a beat.
              • 2.5-12
                • Jan 2010
                • 1814
                bump! probably going to start taking the car apart fairly soon, still trying to book a dyno session first though.
                • SweetLew
                  • Nov 2014
                  • 70
                  I may be interested in this without the turbo, willing to separate?
                  Download the WheelCo App! https://itunes.apple.com/us/app/whee...046704912?mt=8
                  Build Thread: http://www.r3vlimited.com/board/showthread.php?t=344312
                  • 2.5-12
                    • Jan 2010
                    • 1814
                    sure.
                    • e30man94
                      • Mar 2012
                      • 131
                      updated price ? shipped to 29651
                      • 2.5-12
                        • Jan 2010
                        • 1814
                        bump
                        • 2.5-12
                          • Jan 2010
                          • 1814
                          conservative tune pull @ 11psi 22xAWHP 26xAWTQ
                          • 2.5-12
                            • Jan 2010
                            • 1814
                            bumpity bump
                            • 2.5-12
                              • Jan 2010
                              • 1814
                              bump -- setup comes out of the car next week.
