5 Lug AND Big Brake Kit (BBK)
  • Wh33lhop
    • 11705
    Have you considered brake bias when choosing the e46m fronts and 540i rears?
    paint sucks
    • 95///M3
      • Mar 2005
      • 181
      What rear brake lines do you use?
      • dmjensen
        • Jan 2011
        • 799
        Bought one of these kits before this thread was up and the quality is on point! I've machined parts before myself and my work doesn't hold a candle to this product.
        He has very quick response time aswell, if I had a use for a second kit I wouldn't hesitate to buy another.
        • elcoy
          • Jan 2011
          • 569
          Brake bias has been calculated to be slightly towards the front.
          The stock E30 front lines work, I replaced the fronts with the stock E46 lines.
          The Lineup in order of appearance:
          91 535i
          91 318is 5 Lug/E46M3 Brakes
          91 325is w/ S52
          88 Vert Plastic Bumper Swap
          88 M3 ;D
          91 325ix 5 speed
          89 Vert Royalblau Metallic
          73 2002
          1986 325es --> is swap Rallycross Car!!
          1995 Chevy G30 Tow Rig... *I SOLD A CAR!!*
          1993 525i Granitsilber Metallic Touring
          Need a 91 M5 bad but wife would shoot me...twice
          *UPDATE: got a 93 M5 and still alive
          1972 Jeep Wagoneer
          1975 2002 five speed
          Check out:
          Elhartspeedshop.com
          • JOMARO
            • Mar 2006
            • 116
            1-Do you mean the floating rotor?
            2- Rears are E46 non M rotors (E46 325i etc.)
            [/QUOTE]
            Yes I meant Floating rotors
            2- Can the rears work for any other rotors (e90 320 for example 320 mm ) ?
            • elcoy
              • Jan 2011
              • 569
              2- Can the rears work for any other rotors (e90 320 for example 320 mm ) ?[/QUOTE]
              I believe you would need a new bracket for the front caliper to use the floating rotor.
              I have not had the question about E90 rotors before, or heard of anyone trying it. I would think they wouldn't work if they are 320mm, they would be too large? The E46 325 rotors I used were 294mm x 19 mm.
              91 535i
              91 325is w/ S52
              88 M3 ;D
              91 325ix 5 speed
              73 2002
              1972 Jeep Wagoneer
              Check out:
              Elhartspeedshop.com
              • jburnsbmw
                • Oct 2012
                • 142
                Elcoy
                With the purchase of your kit and the associated parts to complete the build, do you have an estimate price to finish?
                $450 kit
                Parts list $?
                Don't worry about labor I will be doing myself
                I'm just looking for a price range considering you could go with stock to high end parts.
                Thanks
                joe
                E30 Oem M3 Sheet metal conversion build
                http://www.r3vlimited.com/board/showthread.php?t=308422
                https://instagram.com/jburnsbmw/
                • elcoy
                  • Jan 2011
                  • 569
                  Originally posted by jburnsbmw
                  Elcoy
                  $450 kit
                  Parts list $?
                  Thanks
                  joe
                  Including the cost of the kit, I finished mine for about $1100 doing labor myself. If you can replace a wheel bearing you can do this install no problem. Depends on if you are doing used/new and what deals you can find. The most expensive parts can be the calipers/rotors, depending one what you go with. The most expensive part for me was the E30M3 rear drive flanges, with the best deal I found being about $330 for both. Other than that its E36 front hub assemblies, and E30 rear bearings. This is about what a one axle BBK kit is, and you get both axles and a 5 lug swap!
                  91 535i
                  91 325is w/ S52
                  88 M3 ;D
                  91 325ix 5 speed
                  73 2002
                  1972 Jeep Wagoneer
                  Check out:
                  Elhartspeedshop.com
                  • mike87
                    • 300
                    can you provide installation instructions?
                    • elcoy
                      • Jan 2011
                      • 569
                      I provide full picture instructions in the kit!
                      Just so people know what they are getting into I can describe the install. Its essentially replacing a wheel bearing front and rear. This can be easy or harder depending on if you have the correct tools to do it. In the front you press spacers into the E36 hub assembly with a vise and reinstall as stock. The brake dust shield must be removed or modified to fit larger calipers. The only other extra step is mounting the brackets where the stock calipers go, then mounting the new calipers to the brackets.
                      Hope that helps!
                      91 535i
                      91 325is w/ S52
                      88 M3 ;D
                      91 325ix 5 speed
                      73 2002
                      1972 Jeep Wagoneer
                      Check out:
                      Elhartspeedshop.com
                      • svn2002s
                        • Sep 2004
                        • 472
                        "The stock E30 front lines work, I replaced the fronts with the stock E46 lines. "
                        Are you saying you are using front e30 lines for the rear and for the front you are using e46 lines (front or rears?).
                        Please be specific.
                        1- which lines for front (e##, F or R)
                        2- which line for rear (e##, F or R)
                        • elcoy
                          • Jan 2011
                          • 569
                          Please be specific.
                          1- Stock front lines that came with my E46M3 front Brakes 34322229723
                          2- Stock E30 Front Lines 34321159890
                          91 535i
                          91 325is w/ S52
                          88 M3 ;D
                          91 325ix 5 speed
                          73 2002
                          1972 Jeep Wagoneer
                          Check out:
                          Elhartspeedshop.com
                          • Eydreeyun
                            • 584
                            Either set up works. Jb325is used e46 m3 front lines for the rear and e30 stock lines in the front. Or you could do what elcoy did. E46 m3 front lines and e30 front lines in the rear
                            • elcoy
                              • Jan 2011
                              • 569
                              Thanks for the info! I am sure there are multiple ways to make it work, thanks for confirming another option!
                              91 535i
                              91 325is w/ S52
                              88 M3 ;D
                              91 325ix 5 speed
                              73 2002
                              1972 Jeep Wagoneer
                              Check out:
                              Elhartspeedshop.com
                              • elcoy
                                • Jan 2011
                                • 569
                                I have answered some questions via PM, anyone else have questions? I can ship Saturday morning, but have a track day Sunday!
                                91 535i
                                91 325is w/ S52
                                88 M3 ;D
                                91 325ix 5 speed
                                73 2002
                                1972 Jeep Wagoneer
                                Check out:
                                Elhartspeedshop.com
