FS: eta Manual trans swap + free 4-door shell!
  • JeffNJM3
    • Dec 2004
    • 666
    What Ive got is a stripped 86 325e 4-door with a overheated engine and 5-speed trans. Perfect for a 5-speed swap into your car. Everything is there that you need. The car is stripped otherwise, no interior, no right front fender, no hood, no trunklid. Its bassically going to be a rolling shell with the partially stripped engine and complete trans, open diff, and the doors and glass will still be on it. The car struck a deer and could be used if you want, it would need a radiator support and all the parts that i parted out replaced. Car does come with a clear NJ title. Trans shifted great before the accident. Can it be used in an i car? I think so, but i'm not sure, please check this out before buying. I had an 86 325 e tranny with a 90 325i motor in my 86 325, so Im sure its possible. Car must be picked up with a trailer or flat bed, if your not to far, i may be able to deliver.
    $250 and its yours
    All Your Base Is Belongs To Us
  • JeffNJM3
    • Dec 2004
    • 666
    bump
    • Ender.
      • Jun 2006
      • 244
      If only you were closer...
      Keep on Keepin' on.
      • James Crivellone
        Head Janitor
        • 6301
        For the record you can use an ETA Getrag transmission on an I car without issue.
        The only thing you need to do, is as the I engine will probably use the I clutch disk/pressure plate, you will need to purchase a slightly longer throwout bearing (as the ETA bellhousing is a HAIR longer then the I)
        21 51 1 204 525 is the longer throwout bearing, used mainly on 733i manual cars in the late 70's/early 80's, but it will work with the above combination.
        • JeffNJM3
          • Dec 2004
          • 666
          thanks for the info bump
          • new guy
            • Sep 2004
            • 467
            Jeff,
            Interested in selling the trans seperate? I have a 325i with a bad trans after 210k. I don't mind getting a different throughout bearing... If I was within driving distance I would pick up the whole car...
            Those that think they are, are not as they really are...
            • golfdmb18
              • Dec 2005
              • 886
              damit, i need this car. Free Bump
              • PУCCKAЯ_e30ka
                • Jan 2006
                • 1226
                damn.... $250 for tranny swap is nothing.... GREAT DEAL!
