So.. Where to begin.. Just posting it all for sale. I CAN GIVE COMBINE PRICING / PACKAGES. Just PM me.
It's unfortunate that I have to do this, but sometimes in life things come up unexpectedly.. Hate to do this but, up for sale i have the following:
S50 Engine. ZF M3 Trans. Removed from a 1995 M3. 138k Miles on both. Now this engine was removed from a parts car that I picked up about a year ago. It ran great, no smoke ect. Was parted out due to being salvage title and not fixable. My plans with this engine was to take it and put it into the e30 that I have turbo ect. however something came up that I need to take care of. The following had been replaced. Keep in mind ALL PARTS are OEM BMW. Purchased right from the dealership local to me.
List: All New OEM ( I DO HAVE BMW RECEIPTS )
- Resurfaced cylinder head (cleaned, hot ranked ect.) Super tech valve stem seals. Stock s50 cams.
- Freshly powder coated black valve cover
- New valve cover gasket
- New 0 Miles MLS .140 Headgasket (Installed)
- New 0 Miles ARP studs (Installed)
- New metal thermostat housing
- Mishimoto thermostat
- Block is stock w/ painted black bottom end
- New timing cover gaskets
- Both chain guides
- Front main seal
- Rear main seal
- Cam position sensor
- Crank position sensor
- Oil pan gasket
- Pick up tube gasket
- Exhaust manifold gaskets
- Dipstick O-ring
- Timing chain head tensioner
- Vanos line
- Oil filter housing gasket
- Exhaust manifold studs & new nuts hardware
- Intake manifold gaskets
- E34 oil pan set up (Front Sump)
- Oil pan tapped for turbo drain
Additional parts:
- Walbro 450 Fuel pump
- Rally Road Turbo Feed block adapter
- Turbo drain / Turbo feed (Off the turbo)
- 4AN turbo feed line / fittings
- Blunt tech / Rapid spools t3 Manifold
- T3 vibrant gasket
- 3" intercooler piping w/ clamps & couplers
- Mishimoto intercooler (3" inlets) 31"
- 20 ft 8AN black braided fuel line
- 20 ft 6AN black braided fuel line
- 2 ft 10AN black braided fuel line
- 2 ft 12AN black braided fuel line
- Z3 short shifter
- 12AN Aluminum fitting
- 6AN Aluminum fitting
- 8AN Aluminum fitting
- 6AN Steel fitting (for fuel pump hanger)
- 8AN Steel fitting (for fuel pump hanger)
- 325e drive shaft (24v swap driveshaft)
- 2.93 LSD (No leaks ect. Smooth as butter)
- Meth fitting / bung for charge pipe
- New 16x8 CNT White wheels Brand New tires (0 miles)
- GC coils (spring set up in the rear) came off a car I bought.. Don't know much about them to be honest
- 413 Red label DME (M50)
- OBD1 Harness (no cut wires ect)
- M50 intake manifold
- M20 AKG Trans / Engine mounts
- M20 Auto Trans
- M20 b25 bottom end w/ oil pan
- M20 b25 bare bottom end w/ rods & pistons
- M52 cams
- M52 cylinder head casting
- M50 / S50 cam trays
- M52 / S52 can trays
- Leather E brake boot
- Leather shift boot
- (3) m20 cylinder head gaskets (w/ valves & springs)
- M20 starters
- M20 intake manifolds
- M20 valve covers
- 3" v band stainless steel Downpipe
- 3" exhaust turbo back stainless steel
- Momo steering wheel w/hub
- Rally road 2 gauge pop behind steering wheel
- Momo shift knob (anodized black)
- Crack free e30 dash
- Tan cloth e30 sport seats
- White front plastic bumper (Late model) SOLD
- White rear plastic bumper (Late model) SOLD
- White front valance (Late model) SOLD
- Bronzit front valance (Late model)
- m20 b27 DME
- M52 Intake Manifold
- M52 Injectors
- M50 Oil Filter Housing
- M52 Oil Filter Housing
- E36 Oil pan
- Black e30 sport seats
- Black e30 carpet (Needs conditioning / cleaning)
- Black e30 door cards (Coupe)
- Tan e30 door cards w/ black handles (Coupe)
- Tan e30 door cards w/ tan handles (Coupe)
90 325ic auto Clean Title
It has been sitting just never got around to it.
Alpine White exterior
Black interior (No front seats)
The car has no drivetrain (Engine/Trans) It is a roller in stock suspension ect.
Engine/trans and front seats are missing, the rest is there.
More will be added... Don't low ball me however I'm willing to work with you. Shipping is available but on your dime. 8607134504
- Both chain guides
- Front main seal
- Rear main seal
- Oil pan gasket
- Dipstick O-ring
- Vanos line
Additional parts:
- T3 vibrant gasket
- Z3 short shifter
- M20 Auto Trans
- M52 cams
- M20 starters
- M20 valve covers
- m20 b27 DME
- M52 Injectors
- E36 Oil pan
