1988 325ix Partout and liquidating my other e30 stock
Are the strut mounts any good? Mine are cracking big time!
They look to be okay from what I can see but I will take them out and get some pics. Planning on taking parts off and getting individual pics as well as some prices.
So, I promised my wife I would liquidate many of my e30 stock since it was taking up precious space in my garage. Finally got around to doing it so these are the parts I need to get rid of.
Everything is OBO unless stated as firm.
Brand new sport seat release cables PN 52101916613 (4 total) - $15 shipped
Stock 14 lb/hr M20 injectors from 1989 325is - worked when pulled - Free + shipping ($6.80 for USPS flat rate box in CONUS)
Used spark plug wires - great shape except for wire for cylinder 3 which has a broken boot (which is why I replaced the set). Good for someone looking to replace one of their bad wires. - $18 shipped
Brand new spark plug wire holder/ignition wire tube PN 12121719889 - $20 shipped (this usually costs ~$35 without shipping from vendors)
Replica e28 rear spoiler - made of some sort of plastic - Looks great but will only fit an e28 since it doesn't flex. Painted with bumper paint (previous owner) and has a crack right above the roundel cutout - $50 shipped OBO
E28 OEM sunroof wind deflector with brand new mounting hardware - $30 + shipping
Universal remote washer fluid reservoir and pump ($18 on Amazon) - $5 + shipping (really light so shouldn't cost much)
E32 Brake booster (with spacer) and original master cylinder. Will include new reservoir grommets and original reservoir, new vacuum hose grommet and original L connector. Great shape, but decided to go back to stock on my car. - $100 shipped OBO
Brake proportioning valve - $20 shipped
M20 late model vacuum connector - $10 shipped
Here it is on my car during my build (before removal)
Remote oil filter setup - includes block connector and two remote oil filter mounts, and hose with barbed fittings, etc. - $40
M20 oil cooler block unit - $20 shipped
Oil cooler - 6/10 condition - $20+ shipping
Only have one of the hoses so PM me if you want that one
(see previous pic) 1989 325is factory front sway bar with slighly used end links and new rubber bushings - $60 + shipping
BMW 2002 reservoir (brand new) - will include OEM BMW 45 degree connectors and those hoses connected as shown - $20 shipped
RARE - E32 V8 remote original reservoir with level sender and factory master cylinder connectors with the original vacuum formed lines (cut by parts puller). THESE ELBOWS CANNOT BE PURCHASED NEW FROM BMW
Perfect for you engine swap guys with limited clearance. - $45 shipped FIRM
Trunk light with switch - Add a second light to your trunk! Can separate switch (perfect condition) from bulb holder and pigtail - $10 shipped together
(shown in last pic) Steering rack tie rod securing plates (pair) - $3 shipped
PN 32111124540
SPAL electric fan hangers - brand new but missing one end from each (uwed for my own car - $7 shipped
Hazard flasher - (4 total, 2 with pigtails) - $10 shipped ea
Defrost switch (1) - $10 shipped
Random connectors - PM me
Similar part numbers
White Connector 61-13-1-378-417
Grey Connector 61-13-1-378-418
Yellow Connector 61-13-1-378-419
E30 washer reservoir with working pump and new cap (the black cap since the oem one is NLA) - $20 + shipping
Hidden antenna kit (planned to shave my antenna) - $8 shipped
Wire loom holder - mounted to blower fan cover- $7 shipped
E36 switches - free
e36 rear switch bezels (needed to to convert your e30 window switches to e36) - $2 shipped each (3 total)
Working ignition switch - pn 61321374967 - $20 shipped
1989 325is front calipers with hangers - were removed and sand blasted (mostly)- worked fine when removed but I converted to BBK - $30 shipped
Will require rebuilding
173 ECU - NO CHIP - everything except the chip which you can source yourself pretty easily - $40 shipped
Extended lug bolts (8 total) for use with 15mm spacers - $20 shipped - barely used
US Check panel - $15 shipped
Wiring harness C101 connector holder - brand new - pn 12521710729 - $7 shipped ($9 from ECStuning)
Adapter bracket PN 61131377270 - $?? free with the holder
(3 total) Trailing arm boot kits - offer me
C191 connector pins for parts - ask
MAF connector adapter - rectangular to round connector - i.e. m20 AFM to e36 MAF - $8 shipped
Wiring harness hold downs (under carpet) - $0.50 each
Coolant/Oil Drain Plug - P/N 07119919225 (3 total) - used to block off throttle body heater lines from block - $2 each
M30 Airbox with good AFM boot - $30 shipped
Door Sill Strip - Right - Coupe - PN 51471906724 - Brand new in packaging (costs $30 from FCPEuro and $47 from ECStuning) - $20 shipped
Late model front bumper adjustment brackets (on fenders) - PN 51111953097 & 51111953098 - $8 shipped for pair
Late model expansion tank with fender connector piece (usually lost) and relatively new (working) level sensor - $20 shipped
1990 525i E24 intake air cleaner box (similar to E30 but AFM isn't angled) - $20 + shipping
Stock e30 spring hats - sandblasted to raw aluminum - $20 shipped for pair
I can powdercoat these if you like - PM me
Bosch Aux Fan Resistor block - Brand new - PN 17401373177 - $10 shipped
Brand new Garagistic clutch pedal bushings - $10 shipped
Working TRE fuel pump- not kit, just pump - $40 shipped
Radiator Aux fan temp switch housing connector (3 pin) - $3
Henna mirrors - pair - bought from CubbyChowder but never used - $50 shipped
Lachsillber mirrors - passenger side glass cracked - $30 shipped
Transmission skid plate - $30
Late model driveshaft harmonic balancer - free + shipping
Driver side late model taillight bulb housing - one broken other in good shape - $20 shipped for both
US Ellipsoids - usual pitting - includes bulb pigtails (converted mine to Euro so not needed) - $120 shipped
Fender roller - bought off ebay and used once - $40 shipped
Pair of 10mm spacers - one has broken off hubcentric ring - $8 shipped firm (cost to ship only)
US ellipsoid low beams - smoked and resealed - $ask
Half of High beam crosshairs - does not include matching half to make complete - someone could make the other half - $8 shipped
Coupe silver trim - nearly complete set - picked up or you pay for special shipping - FREE FREE FREE FREE
(3) door handles - $5 each obo
E30 tool tray - Free + shipping
Late model charcoal canister with powdercoated bracket (silver vein) - $5 + shipping
Evap purge valve - $5 (above)
(2) M20 afm for parts - one missing cover - works but needs TLC - $20 shipped ea
Rear shock bellow/covers - Free + shipping
Also, I have a 1988 325ix coupe I am parting out. See pics in prior posts! I probably have some other parts so feel free to ask and I'll message you back.
rear shelf if it had premium speakers and late model tail light?
okay to message me 614208 four 7 23
Sorry, the previous owner took the rear shelf with speakers. Keeping the taillights since I'm using this shell to build a trailer.
Originally posted by sampayne
What size fittings on the prop valve?
I will check tonight and let you know.
- Ben
Rear sway bar from 325ix is not for sale. Sorry guys. Building an e30 trailer with the shell so keeping most of the suspension stuff. No differential either. Differential output flanges are available from that car but have damage since they were left on the trailing arms and allowed to scrape the ground while moving (Previous owner I got the shell from didn't give a crap about the car).
IX flares are available and in great shape. Will need new fasteners though. Willing to ship anywhere on buyers dime. Yes, even out of country ;D
Hey, any chance you have an IX booster? If so, let me know asap. Thanks!
Kevin-- 704-858-0155
I have an e32 735i booster setup which is what was used on the post 1990 IX models, IIRC. You need the correct master cylinder for it though, which I have paired with it. Everything works and is in great shape. Needs a lick of paint and it'll be perfect (spilled some brake fluid on it while removing).
Alternatively, I have the booster with spacer from the 88 325ix booster in the parts car. It's the single diaphragm version though, not the dual diaphragm like the e32 booster.
Needs some TLC so I'll let it go super cheap. This was a daily driver so I assume it works; refund if not.
