Garage30 Drive Shaft Adapter Pre-Order - Neue Motorsports
  • Dylanhat
    • May 2013
    • 557
    Hey everyone,
    I'm pleased to announce that my website Neue Motorsports is parterning with Garage30 out of the Netherlands. For the US market we will be doing a pre-order for R3v and people who use our site. All US buyers will get free shipping. If your international we can figure something out. Here's some info on the product:
    This adapter kit is designed to couple a medium sized 96mm p.c.d flex disc (also known as giubo) to a stock e30 78mm p.c.d driveshaft. The 96mm transmission output flange is mostly found on the M5X/S5X family of engines with the 5-speed transmission. It is also found on the M60B30 v8 with the 5-speed. This means if you swap any of these engines in your e30 you can keep your stock driveshaft, instead of having to source an e30 M3 big flange drive shaft ($$$), or use a aluminum swap flex disc. The advantage of using this adapter over a aluminum swap guibo, apart of being cheaper, is the use of a stock flex disc which permits way more driveline deflection without failing. That said, near perfect driveline alignment is still important for a vibration free drive. The adapter is laser cut from Swedish high quality, high strenght steel. Lower quality steel simply didn’t last. Threads are cut, and it is then ground perfectly flat to a 0.01mm tolerance for perfect balance. Lastly it gets an anti corrosion zinc gold finish. Bolts supplied are 12.9 quality zinc finish. Can also be supplied with bolts and nylock nuts to fasten the flex disc tot the transmission for a complete kit. We tested the adapter in a M60B40 swapped e30 325i. We are a small Dutch company owned by e30 enthusiasts. Fully made in the Netherlands. Our strict D.M.V approved the use of this adapter for a road vehicle. What do you get in the base kit? The adapter plate, 3x M10 bolts, 3x M12 bolts, washers and the instructions.
    Order now: http://www.neuemotorsports.com/store...ft-adapter-kit
    Neue Motorsports: http://www.neuemotorsports.com/
    Instagram: https://instagram.com/neuemotorsports/
  • jhaurimn
    • Nov 2012
    • 2224
    Good stuff!
    Current:
    1989 325i
    1988 M3
    1987 325ic
    Past:
    2001 330ci
    2001 M3
    • Mr. Burns
      • Aug 2011
      • 3516
      you'd still need to shorten the DS no?
      Originally posted by flyboyx
      i have watched my dog lick himself off a few times
      • JGood
        • Jan 2004
        • 7959
        That thing looks to be less then 1/2" thick, so the stock driveshaft should collapse enough to compensate.
        Cool product! Seems like it would get the job done without any drawbacks.
        e30 restoration and V8 swap
        24 Hours of Lemons e30 build
          • 37825
          Very cool!
          Classic BMW Specialists
          Santa Clarita, CA
          www.BimmerHeads.com
          • Dylanhat
            • May 2013
            • 557
            Originally posted by jhaurimn
            Good stuff!
            Thanks!
            Exactly.
            Originally posted by MR 325
            Very cool!
            Thanks!
            • mr2peak
              • 2388
              Do you balance these before shipping?
              Drive it hard. Maintain it well.
              A Topless Memorandum
              • Garage30
                • Aug 2015
                • 123
                Thanks guys, just wanted to chime in on some questions
                The adapter plate is only 8mm thick, there should be more than enough room in the driveshaft's slide coupling to allow for that. But it is the reason we chose a high strength steel, to make it thin and still strong enough.
                The adapter is cut very precisely, the holes line up absolutely perfect. We also grind it flat on both sides to 0.01mm, like decking a block or cyl head. This gives a perfect balance.
                Euro car and parts export business based in the Netherlands, specialized in E30 Tourings!
                Instagram: @garage30_ WWW.GARAGE30.NL
                • Dylanhat
                  • May 2013
                  • 557
                  bump
                  • flyboyx
                    • 8371
                    so it appears that this kit adapts the medium sized guibo to the small e30 bolt pattern?
                    can you make an adapter to go from the large 540i/m5 guibo to the medium size?
                    Gigitty Gigitty!!!!
                    • Dylanhat
                      • May 2013
                      • 557
                      In the future I'm sure that could be done.
                      • Dylanhat
                        • May 2013
                        • 557
                        We have 3 kit currently in stock. All pre-orders will go out tomorrow also. Thanks for the support everyone.
                        • Dylanhat
                          • May 2013
                          • 557
                          bump
                          • Sh3rpak!ng
                            • Jan 2014
                            • 2667
                            dammit, where was this piece 4 months ago when I swaped to the zf transmission?!!?
                            nice piece! I'm surprised someone didn't do it sooner!
                            Shadetree30
                            • ClassThirty
                              • Jan 2016
                              • 45
                              Tried the online order form but it doesn't have the option for free shipping.
                              1990 325i/4/5 Delphin Grey/Natur
