complete turbo set up for e30, engine, ecu, turbo, etc. obo - No Longer Available
  • fullytorquedracing
    • Sep 2016
    • 3
    Hello everyone, Ive decided to sell the clean turbo build in my e30 to start my new build. This is for all the engine/turbo/ecu components, not the whole car! This car is my dd with a solid megasquirt tune from Carolina Dyno running 18psi. I will leave the engine in until a buyer comes along and you can hear the engine run and go for a ride down the street if you would like. Would only take a couple hours to pull and you could come back and pick it up. This could be dropped into your e30 in a day and you would have one mean little e30. Asking 4k for the whole set up. This is a quality build and not some half-assed assembly. if you have any questions feel free to text or call the number above
    M20b25
    O-ringed block
    New camshaft
    New rocker arms
    Arp head studs
    Bosch 30#injectors
    New timing belt kit (belt, tensioner, water pump, etc.)
    New oil pump
    Larger oil cooler
    Oil pan bung welded for turbo oil return
    Oil filter relocation kit
    New distributor cap and rotor
    Spark plug wires and coil
    New iacv
    Water pump clutch delete, electric cooling fan
    6 puck clutch
    Heat wrapped exhaust manifold
    Cr Racing exhaust manifold modified for external waste gate
    Tial 38 external waste gate 18# spring
    Holset Hx35 turbo running 18 psi
    Megasquirtpnp ecu
    Custom 3in down pipe with full 3in exhaust, new borla muffler
    Tuned at Carolina dyno, runs and pulls like a dream
    Literally everything you would need to immediately go from an NA to sick turbo build. Consider it a plug and play turbo build, no piecing together required.
    List Date: 9/6/2016
    For more info, click here to view the original listing: complete turbo set up for e30, engine, ecu, turbo, etc. obo
    This item is no longer available.
  • E30xium
    • Oct 2015
    • 96
    How much is the gain on this set up?
    "Stand tall and shake the heaven."
    "Stand Tall and Shake the Heavens"
    • ethurtee
      • Jan 2013
      • 1989
      Dyno sheets? Mileage on setup? Cam manufacture/specs? Any leaks? What octane is it tuned for?
      • RHDE30Touring
        • Feb 2016
        • 59
        Hey, very interested in this. Would you happen to have receipts of the build? Documenting what was done? Let me know. Pm me.
