Garage Clean Out! E36 M3 and E30 M20 Parts- a little bit of everything! Updated 4/1
  • Klug
    • Sep 2011
    • 804
    Updated 4/1 Help clear out this junk!
    Starting to some late cleanup around the shop. Needed to get this stuff posted. Parted out an E36 M3 and E30 M20 engine recently- here is what I have laying around.
    All OBO and Shipping costs additional or local pickup in Kingston, PA 18704
    E30 Parts
    Auto Shifter - $20
    Auto Trans Brake Pedal with cleavus- $5
    Auto Trans shift linkage - $20
    Bell Housing part that goes above M20 oil pan - $10
    Bitch Tube with spring - $10
    Diag Port Holder Bracket- $5
    E30 325i Auto Drive Shaft- $60
    E30 Stock Booster - $40
    E30 Stock Mid Exhaust - $40
    Heater Core Bypass Valve - $5
    M20 (2) oil pumps - both working - $50/each
    M20 (30) Injectors - $5/each
    M20 Auto Tranny - $200
    M20 Block - $300
    M20 Cam Sprocket Cover - $5
    M20 Crank (Bearing wear) $50
    M20 Crank Position Sensor - $40
    M20 Crank Pulley - $10
    M20 Fan blade - $5
    M20 Fan Clutch w/ fan (2) - $20/each
    M20 Fuel Rail with FPR - $30
    M20 Injector Rail - $20
    M20 Misc Piston's and HW - $50
    M20 Motor Mounts Arms - $30
    M20 Power Steering Pump - $50
    M20 Rear Main Seal housing - $10
    M20 Starter - $30
    M20 Stock Exhaust manifolds - $40
    M20 Timing belt sprocket - $5
    Manual Pedal Bracket - $20
    Misc Intake Boots - $10
    OBC 13 Button harness - $20
    OBC 13 Button, no light bar $60
    PS reservoirs (have a bunch of misc lines) $5/each
    R12 AC Compressor - $30
    Rearview mirror - $10
    Red Label DME - $100
    Stock 325i Emblem (From '89 Coupe e30) - $20
    Stock 325i Power Steering Rack, rebuilt - $60
    Stock Rear Sway (From '89 Coupe e30) - $30
    Tranny Stop Bracket - $5
    Vert Passenger Side wire cover - $5
    Washer bottle - $5
    Water Pump - $20
    S5x Swap Parts
    M50 ODB1 Fuel Rail and FPR - $30
    E30 Rebult Steering Rack - $80
    E36 S52 S50 M3 Parts
    **All parts were working when removed from '95 E36 BMW Coupe (with '98 S52 swap)**
    328i Tails (Passenger side top cracked) $20
    A/C Dryer - $5
    A/C Fan - $50
    A/C Lines (all of them) - $30
    ABS Module - $10
    ABS Pump - $70
    AC Lines/Dryer/Switches - $100
    Ashtray - $5
    Booster - $60
    Brake Fluid Resivor - $10
    Bumper Shocks - $30
    Center Console w/ leather e-brake pull - $40
    Center Shift/window console - $50
    Climate Control Module - $20
    Cruise Control Module and linkage - $20
    Custer - $100
    Dash - $100
    Dash Defrost Vent - $5
    Dash Dimmer Switch - $5
    DME/ECU Cover - $5
    Door Cards - Slight delamination from moisture and small tear on pull of passenger side. Other than that, probably better than what you currently have - $100 full set
    Door Latch (2) - $5
    Door Lock Assembly - $20
    Door Seals (whole car) $5 each
    Driver and Passenger side glass - $50/each
    Drivers side vent - $5
    E brake Leather Pull - $30
    E36 M3 Guibo, never used 96mm - $50
    E36 M3 Stock Exhaust, Cat-Back - $100
    E36 PS Rack- $100
    Floor Mats - $30
    French fog (1)- $20
    Front Calipers - $200
    Front Rotors and Blue Hawk Pads- never even broken in - $100
    Front Spindles and Control Arms - $300
    Front Subframe - $70
    Front Swaybar - $50
    Fuse Box Cover - $5
    Gas Pedal - $5
    Glove Box (working) - $100
    Headlights - $60
    Heater Core Saftey Module - $5
    Hood Hinge (2) - $15
    Horns (2) - $5
    Interior Door handle - $5
    Interior Light Bezels - $5
    Jack - $20
    Knee Bolster - $30
    M3 Exterior Side Molding - $100
    M3 Side Mirrors - $200
    M3 Tails (slight crack on passenger side lower left...not noticeable) $50
    Manual Driveshaft with 6 bolt CV rear - $100
    Master Cylinder w/ Reservoir - $50
    Misc Modules, Horns, Bushings, Switches, Covers, Buttons etc etc - throw me an offer.
    Misc Trim pieces - $5 each
    OBC - $30
    Passenger side fender - $80
    Pedal Assembly - $60
    Positive Terminal Distribution Block - $10
    Radiator Support, Cover, Fan Shroud - $30
    Rear pop-out windows w/ gaskets - $100
    Rear Speaker Covers (2) - $10
    Rear Subframe, excluding diff but everything including sway- $300
    Rear Subframe, excluding diff- $300
    S52 Airbox - $50
    Seat Belt Lock - $5
    Seat Belt Lock Frame Bar (2) - $5
    Seat Belt Rear - $5
    Seat Belts - $10/each
    Shift Boot Leather - $30
    Side Skirts (Twisties) - $150
    Speaker Kick Panels Front - $5
    Steering Column - $100
    Steering Wheel- M3 stitching w/o airbag, real good condition - $100
    Steering Wheel- M3 stitching with airbag, real good condition - $110
    Stock Amp - $30
    Strut (Front) Cap (2) - $5
    Sway Bar Clamp - $5
    Sway Bar Front with linkage - $40
    Sway Bar rear - $40
    Tail Light Covers - $20
    Tan/Black seats - $250 OBO
    Trunk Lid w/ rust around license plate hole - $60
    Trunk Lid w/o rust - $100
    Trunk Strut (2) - $20 Pair
    Visors (2) - $10
    Washer Bottle - $10
    Wiper Motor/Arm - $50
    ZF Tranny Cross member - $20
    [/URL]
    555Garage - Kingston, PA
    '13 BMW e70 X5 35d
    '95 BMW e34 525i
    '92 BMW e30 325i S52 Vert (Quade the Vert)
    '92 Range Rover Classic
    '90 Range Rover Classic
    '89 BMW e30 325i Coupe (The DIRTY30)
    '81 VW MK1 Rabbit Caddy Diesel
    '76 Honda CB550K Cafe/Brat
    '67 Pontiac LeMans
    '24 Model T Depot Hack
    ....And a bunch of Motobecane, Puch, Garelli, Batavus and Honda 49cc-78cc Mopeds...
  • prada88m3
    • Dec 2010
    • 211
    year mileage and condition of the steering racks
    • dzverko
      • Feb 2013
      • 92
      PM sent for M20 flywheel and associated parts
      Sent from my VS985 4G using Tapatalk
      • Klug
        • Sep 2011
        • 804
        bump
        '13 BMW e70 X5 35d
        '95 BMW e34 525i
        '67 Pontiac LeMans
        • Klug
          • Sep 2011
          • 804
          bump
          '13 BMW e70 X5 35d
          '95 BMW e34 525i
          '67 Pontiac LeMans
          • Cha Ching
            • 1668
            Klug, can you post a better (close-up) pic of the M20 oil level sensor? Any cracks or splits with it? It functions correctly? Do you know the year? I have a '91 M20 motor. Thanks.
            • Klug
              • Sep 2011
              • 804
              It came off of the '92 M20 vert, works and all. Just the connector end is broken so the pins are exposed. You can use your old one or just wire it in directly. It worked when removed.
              '13 BMW e70 X5 35d
              '95 BMW e34 525i
              '67 Pontiac LeMans
              • Kershaw
                • 11822
                Can you take a few close up pics of the hood? Especially the leading 12"?
                AWD > RWD
                • Klug
                  • Sep 2011
                  • 804
                  the e36 hood correct? and by leading, do you mean front or back end?
                  '13 BMW e70 X5 35d
                  '95 BMW e34 525i
                  '67 Pontiac LeMans
                  • Cha Ching
                    • 1668
                    Thanks, Klug. But mine looks like that as well. Still works, too. Just trying to clean things up.
                    • Klug
                      • Sep 2011
                      • 804
                      Bump, lots of this stuff still taking up space in my garage. Lump some items together and I'll show you a "Cyber 'Monday' Special" you sicko's.
                      '13 BMW e70 X5 35d
                      '95 BMW e34 525i
                      '67 Pontiac LeMans
                      • Klug
                        • Sep 2011
                        • 804
                        Updated- All parts OBO!
                        '13 BMW e70 X5 35d
                        '95 BMW e34 525i
                        '67 Pontiac LeMans
                        • Matt-B
                          The Waffler
                          • 3856
                          have e36 front shift boot also or nah?
                          And would you sell just the vents above glove box?
                          • cherryE30
                            • Jul 2016
                            • 18
                            Parts
                            Parts still available:
                            E36 steering rack?
                            m20 Starter?
                            Front and rear sway bars w/bushings?
                            alternator (M20)?
                            brake booster?
                            Passenger seat belts?
                            Seats?
                            m20 subframe?
                            pm me if you still have parts..
                            Cherry E30
                            Hempstead, NY
                            RespectURelders
                            • Klug
                              • Sep 2011
                              • 804
                              Yep- I think I actually have (2) e36 leather shift boots..need to verify and yes- I'll part the vents out of the glove box too. Let me know if you wanted (2) or (1) of the shiftboots and i'll work a price out with ya.
                              Thanks!
                              '13 BMW e70 X5 35d
                              '95 BMW e34 525i
                              '67 Pontiac LeMans
