Made from aluminum aircraft grade 7050-T7651 KaiserSelect USA,
high grade alloy steel 4340 | 36CrNiMo4 | 1.6511 | EN24 | SNCM439 steel JAPAN,
high tensile 10.9 grade locking bolts
here for more detail about al. 7050 material
Price is 399.00 + shipping
With this setup offset or track width will change
- front : +14.5mm each side
- rear : +2.5mm each side
Benefit this with this setup :
1. Keep stock e30 suspension geometry
2. 70/30 brake bias, which good for street/auto-x/track
3. wider tires/wheels on rear using staggered wheels
It require minimum 16x8 style 5 for 16s only to fit e46m3 front brake
and most 17s OEM or aftermarket wheels
Parts that you need beside the adapter kit are...
>> Front :
1. e46m3 calipers left + right - (a pair)
2. e46m3 brake pads - 34112282416 - (x2)
3. e46m3 caliper bolts - 34116767217 - (x4)
4. e46m3 rotors left - 34112229529 - (x1)
5. e46m3 rotors right - 34112229530 - (x1)
6. e36/46 wheel hubs - 31226757024 - (x2)
7. dust cover - 31206777788 - (x2)
8. cap - 31206777789 - (x2)
9. rotor screws M8x12 - 34111123072 (x2)
>> Rear :
1. e46 325/328i calipers (make sure caliper carrier have "506" marking)
2. e46 325/328i caliper bolts - 34203414763 - (x4)
3. e46 325/328i brake pads - 34216778168 - (x2)
4. e46 325/328i rotors - 34216864056 - (x2)
5. rotor screws (M8x14) - 34211161806 - (x2)
6. z4/e90/e92 hubs - 33416752381 - (x2)
7. e30 rear wheel bearing - 33416762317 - (x2)
8. axle nuts M22x1.5 - 33411125664 - (x2)
Optional parts
9. e46 325/328i backing plate, left - 34211158991 - (x1)
10. e46 325/328i backing plate, left - 34211158992 - (x1)
11. e30 drum T/A steel brake pipe - 34323412744 - (x2)
12. 12mm wheel spacers - (x2)
Brake M/C need to upgrade, since this setup use bigger caliper pistons diameter...
--> e28 520i brake M/C (23.81mm, non stepped bore) - 34311153053 - (x1)
If not, you will get deeper pedal feel and brake bias 60/40..
-- OR --
--> e32 735/750i brake M/C (25.4mm, non stepped bore) - 34311156643 - (x1)
With 25.4mm brake M/C, you will get shorter pedal feel than 23.81mm one
You need Left hand tap M16x1.5 to do mod on stock e30 knuckle/spindle
step by step installation
here the purchase feedback
For more products, see my FB page & IG
>> Front :
>> Rear :
Optional parts
-- OR --
