[ETA - E30 Adapters] 5 Lug kit with e46m3 front and e46 325/328i brake setup
It should be no problem e38 styl 5 on 330i front brake
Brembo e38 728i fit with styl 5, for sure... because it was designed for this chassis
e38 728i have thick disc brake hat
Yes, but the Brembo fit on style 5 with 316mm disc, no with 325mm disc. The question is if with this change when I put the e38 brembo on 325mm (e46330) disc - caliper will not tuch rim.
Many thanks for all information,
I’ll double check if 318ti on rear won’t fit with my style 5 and 225/45/16 semi slick tire so I’ll buy from you the rear bracket.
Thanks again!
No problem...
Let me know when you ready place an order
Was wondering about a couple of things, how does the parking brake work with this kit?
And is there another reason, except for the 5x120 bolt pattern, that you have to use e46/z4 rear hubs? I am running E34 rear hubs on my car, so if it fits, I will like a kit.
Parking brake work like stock from factory.
Brake shoes pulled with cable to handle inside
Yes, z4 hubs + e46 325/328 brakes to keep parking brake work same like came from factory..
Sorry, I dont have e34 hub.. so, I can't answer it
With stock E30 handbrake shoes?
All right, then I guess I will be trying If it doesn't fit, then I will make it fit Will give you a heads up before I order
All right, then I guess I will be trying �� If it doesn't fit, then I will make it fit �� Will give you a heads up before I order
yes, stock e30 handbrake shoes
cool! thanks
lmk when you ready
