I've got quite a few spare s54 parts from the old engine in my M3. I'll be listing them here as I smuggle them back from MN. The engine had 15x,xxx miles on it before it threw a rod, these are the parts that were deemed usable by the garage that removed the engine. More parts to come, if you want more pictures lmk.
S54 intake and exhaust cams $50, journals look very good, no scoring or unusual wear patterns.
Valve cover, WITH vanity cover, $100
Newer A/C compresser $50
Fuel rail and fuel injectors $50
Both motor mount arms $30
Throttle body actuator $30
Front timing cover, grease ball but in good shape, $20
Engine vent line $5
Fan shroud: $5
Fuel supply line: $5
Camshaft thrust plate, no caps $5
Header heat shield $5
Oil pump suction strainer $5
Fan, probably fits all kinds of bmws $40
Engine wiring harness $100
6 coil packs $40
Power steering pump and reservoir $100 SOLD
Vanos Exhaust hub $450 SOLD
Harmonic balancer $20 SOLD
Oil pump gear and nut $10 SOLD
Vanos unit: $200 SOLD
Vanos solenoid $75 SOLD
Oil filter housing $200 SOLD
S54 throttle bodies $225, they seem to be missing the actuating arm pins. SOLD
S54 crankshaft from a 2002 BMW M3 $400, I bought this planning on using it in my engine rebuild after suspected rod knock but my crank was good so I have no use for this one. It was mag particle checked by the previous owner. Should be good to go! Let me know if you would like more pictures. I would replace the pilot bearing before you install it. SOLD
Engine vent line $5
Fan shroud: $5
6 coil packs $40
