Parting 325i 4dr and 86 327i (e to i swap kit available)- Lots of parts
  • BenM
    • 2184
    #31
    Originally posted by mooseheadm5
    Yup. Need a battery tray, too? I've only got one of those left.
    Now that you mention it, yeah I think I might. Add that too.
    Thanks.
    Originally posted by BillBrasky
    E36's are the Stephen Baldwin of the 3 series family. They barely hold everything together and they only sold a lot because of the popularity of their older sibling.
    1991 318i Alpine II - S50/5-lug swapped - track car
    1989 325i Cirrusblau - Daily
    1970 2500 - Malaga over Grey Cloth
    2012 F350 6.7PSD
    • mooseheadm5
      • Apr 2009
      • 375
      #32
      Pm'd on the batter relocation kit.
      -P
      Moosehead Engineering
      • mooseheadm5
        • Apr 2009
        • 375
        #33
        One battery relocation kit sold
        -P
        • mooseheadm5
          • Apr 2009
          • 375
          #34
          86 Drv rear vent trim piece and second battery tray sold.
          Plenty of good parts left.
          -P
          • bataangpinoy
            • Jul 2008
            • 1636
            #35
            how much for the un modded i cat back?
            My feedback:
            http://www.r3vlimited.com/board/showthread.php?t=186328
            http://e30tech.com/forum/showthread.php?t=74911
            Instagram:
            @gears_n_glory
            @functionmotorsports
            • mooseheadm5
              • Apr 2009
              • 375
              #36
              $75 + shipping will get you the first pick of the two unmodded ones (meaning the better one.) Anything else?
              -P
              • mooseheadm5
                • Apr 2009
                • 375
                #37
                One OBC kit and one CC kit on hold until this evening.
                -P
                • mooseheadm5
                  • Apr 2009
                  • 375
                  #38
                  Boxing up a load of parts today. Also have:
                  Uncracked glove boxes with straps- hinge mounts are not broken! No latch on one.
                  Tweeter panels from the 4 door. Can be sold with or without the Pioneer tweets.
                  Premium sound deck speaker pods. No mids, factory tweets only.
                  90 owners manual convering all E30s
                  Front valence from 90 325i with lip and brake ducts. All clips intact. In perfect shape. Willing to ship. $175 OBO.
                  Pics can be found HERE
                  Or I can post them and waste bandwidth.
                  -P
                  • 86bmw325
                    • 60
                    #39
                    have u made a decision on a ballpark for the swap?
                    • mooseheadm5
                      • Apr 2009
                      • 375
                      #40
                      327i swap kit:
                      Head:
                      ported 325i cylinder head with dual valve springs
                      intake ports enlarged, smoothed, reshaped
                      exhaust ports enlarged and smoothed
                      head milled 0.040" for higher compression
                      comes with valve cover
                      Intake manifold:
                      325i intake ported to match head
                      325i throttle body
                      all ICV, PCV, vacuum and booster hoses, and check valves
                      Fuel rail with FPR
                      Exhaust manifolds:
                      325i exhaust manifolds sprayed with aluminum high temp ceramic paint, but need to be resprayed
                      port matched to cylinder head
                      New valve cover gasket and cam plugs
                      Rebuilt 60k miles ago with new cam seal and valve guide seals
                      Electronics:
                      87 325i wiring harness- verified direct plug in for 86/87 325e - tach and current fuel consumption on OBC will work with no splicing (this is not true of 88 and later harnesses)
                      All sensors including the timing sensor at the balancer
                      plug wires including the #6 wire with sensor needed for Motronic 1.3
                      All injectors (M50 injectors available +$75)
                      O2 sensor
                      ICV
                      TPS
                      AFM
                      ECU
                      Instrument cluster with 7k tach. Everything works on it except the odometer, but we can talk about having that repaired if you need.
                      Misc:
                      All brackets
                      88 325e (super eta) balancer- this balancer is designed for the longer stroke crank. A 325i balancer can be used- it will drive the water pump slower, but it is not sized for the throw on the crank. I can provide either. It is up to you which you want to use. Discount if you don't need either (but you can't use a Motronic 1.1 balancer.)
                      thermostat housing with hose to block off port for throttle body heater
                      plug for engine block to block off other throttle body heater port (never had a problem doing this even in 20 degree weather)
                      Any drive belts that I have that are still good.
                      timing belt and tensioner used for 5 minutes (see notes)
                      Options:
                      325i catalytic converter with 2 in 2 out
                      325i cat back exhaust
                      Late 325i cooling system upgrade- the 327i kit will work with your early radiator just fine. I used my old style radiator with AC on my car for 60k miles with no problem. If, however, you want to increase your cooling system horsepower capacity, I can sell you all of the late model 325i components. This will include the coolant tank with sensor and bracket, late radiator brackets and rubber pieces, all hoses, coolant crossover pipe, fan shroud with clips, and water pump. You may need to redo the wiring for the coolant level sensor, since it will be on the wrong side of the car. You will then be able to run an E36 radiator if you wish.
                      Notes:
                      I am NOT currently interested in parting this kit out. I want to sell it to someone that really wants a 327i
                      I ran this on my 86 and flogged it every day with no problems. The crank took it just fine
                      These components will work on an 86/87 325e with no problems. Any that do not have a round harness connector will require wiring.
                      For super eta/ or 325i owners- this head will fit BUT there may be valve clearance issues because of the milled head. It will be up to you to make provisions for this. There is no such problem with any 84-86 325e, but you should still make certain that everything clears properly! I found out that the valve clearance is too close for comfort on a 325i. That is why you will get a brand new timing belt and tensioner pulley and why the pics show the head installed on the 90 325i. I never got a chance to drive the car this way- I had to back off the valve adjustment too far for the valves to clear the pistons. I did not want to run it this way and am ready to pull it all apart again. I will guarantee that there are no bent valves when it leaves the shop.
                      This kit should be used with an i flywheel (which I cannot provide) and at least a 3.45 diff. I recommend a 3.73. I ran a single mass e flywheel and a 3.25 which was pretty good for towing and fuel economy (31mpg at 75mph), but there is a bit of a lag off idle due to the aggressive porting. This is normal even with a 325i running a 3.25 diff. The top end is fantastic, though.
                      I recommend finding someone that can provide chip tuning to take advantage of the porting and increased displacement over the stock M20B25 engine the software was originally designed for.
                      I will not be responsible if you bend valves due to improper installation, handling, etc.
                      I will photograph, crate, insure, and ship the parts. After that, any damage is not my problem.
                      I will provide technical support over the internet and will provide daytime contact information and the physical address of the shop I work from- you can rest assured that I will not stiff you.
                      I spent a lot of time and scronged for a while to put this kit together. I am getting out of E30s for a while, so I want to pass it all on to someone that needs it.
                      Price:
                      basic kit- $1000 shipped OBO
                      Including full exhaust- $1200 shipped OBO
                      $850 OBO takes the kit and the exhaust if you pick up in Charlottesville, VA or Washington D.C.
                      Add late cooling system components +$125 OBO
                      Add M50 injectors +$75
                      -P
                      • mooseheadm5
                        • Apr 2009
                        • 375
                        #41
                        Parts handed off to evil_twin.
                        Rear bumper gone
                        One of two glove boxes gone
                        90 tail lights gone
                        random crap gone
                        Thanks evil!
                        -P
                        • Unearth078
                          • May 2008
                          • 2623
                          #42
                          do you still have the 90 3rd brake light. i need the bulb carrier inside of it.
                          Originally posted by Lof8
                          4 doors allow you to transport more whores.
                          therefore, their value is much greater.
                          Down to: 89 aw2 332i/4/5 , 70 Sahara 2002
                          • mooseheadm5
                            • Apr 2009
                            • 375
                            #43
                            Yup. I am also going to pull the stereo and see about the wiring today if wifey doesn't make me leave too early. You got dibs on that.
                            -P
                            • mooseheadm5
                              • Apr 2009
                              • 375
                              #44
                              If you paid for it already, it is boxed up and will ship Monday.
                              If you haven't paid for it, it will not ship until Wednesday at the earliest.
                              -P
                              • evil_twin
                                • Nov 2007
                                • 2965
                                #45
                                Awesome seller, awesome guy!
                                Paul, I will have to make it out to RRT to see your brother.
                                Paypal: vdang5@gmail.com
                                Delta Auto Care
                                2875-C Towerview Road
                                Herndon, VA
                                703.435.1375
                                My Feedback Thread: Evil_Twin
