I am hopefully doing the swap in the next month or two. I should have a transmission lined up but I need everything else for the swap. If you have parts that are just taking up space you want to get rid of great. If you want a little compensation for them thats fine to. I will hopefully be getting some quotes on new parts this week but I'm open to any used parts at the moment. I'm just trying to get it done for as little as possible. The individual parts don't cost that much, but they sure do add up quick when you go new. So here is a list of what I'm looking for.
Manual transmission drive shaft
Flex disc (Guibo)
Center suppport bearing for drive shaft
Flywheel
Pilot bearing
Clutch assembly (disc, preasure plate, throw out bearing, pivot pin)
release arm
master cylinder
slave cylinder
clutch hydraulics
shifter assembly (if anyone has a z3 shifter, thats what i'm particularly interested in although I would use the stock shifter to start off if thats all i can find.)
pedal box (from an airbag car)
shift knob
shift boot,
tranny mounts
I have prices for almost everything via bav auto (with the exception of the drive shaft and pedal box I believe). I will hopefully have prices from my dealer source this week. I should be able to get them thru my source for less then the bav auto. If you have anything you want gone I'll take it, otherwise let me know what you have and i'll make an offer based on my current prices. New, used, doesn't matter to me at this point as long as it is all in good functional condition.
Flex disc (Guibo)
Flywheel
Pilot bearing
release arm
master cylinder
slave cylinder
clutch hydraulics
shift knob
shift boot,
tranny mounts
