Stroker crank spacer info etc.. admin pls move to the m20 sub
  • Chrisbike
    • Mar 2015
    • 688
    M20 Crank spacer? Admin move this to m20 section pls
    Build Thread
    https://www.r3vlimited.com/board/sho...d.php?t=419655
    Parts Thread
    https://www.r3vlimited.com/board/sho...d.php?t=408302
  • Dagamus(NM)
    • 612
    Contact john@wot-tech.com
    He is on here, Forced Firebird.
    Gun control means using both hands
    Sex, Drugs, Rock 'n roll. Pick two.
    • Chrisbike
      • Mar 2015
      • 688
      Found that IE supplies them with their 2.9 kit that I'm purchasing. Thnanks..
      Build Thread
      Parts Thread
      • Dagamus(NM)
        • 612
        The ones they have are not very good. I have been through quite the hassles with I.E. and cannot suggest you go with them. In fact I strongly advocate against it. You can easily source a crank on this forum easy enough. Racetep.com or vacmotorsports in philly will have better piston options and based on your stroke and rod will get you whatever compression ratio you want plus coatings and other piston customizations that I.E. doesn't offer.
        • Matt-B
          The Waffler
          • 3856
          I.E. just sells rebadges items i hear?
          Contact levent @Gutenparts he has leads on random items
          • Dagamus(NM)
            • 612
            Depends on the items. Most of their stuff comes straight from China. The crankshaft and pistons are obviously not reps. Crank will be BMW, pistons are made by umm, I forget but a proper piston maker. It is the rest of the "kit" that is overpriced and lacking in quality. My crankspacer had to be removed and replaced at considerable cost. It was so poorly made. Peerless made a thread about a motor he built for me on the other recently resurrected forum.
            • Chrisbike
              • Mar 2015
              • 688
              Ill give IE a call Monday and talk to them about this. I wonder if they know the crank spacers they are providing are bad quality. Im talking to John right now about building some GCs so I will contact him. I sent a email in the meantime
              I purchased Mahle motorsport pistons from them..
              The H beams they sell are forged 4340 steel, they are only 499g each..
              Build Thread
              Parts Thread
                • 37828
                We also offer stroker kits at BimmerHeads. Just an FYI for anyone interested.
                Classic BMW Specialists
                Grover Beach, CA
                www.BimmerHeads.com
                • UgkNW*
                  • Oct 2013
                  • 259
                  Which is the recently resurrected forum?
                  • Chrisbike
                    • Mar 2015
                    • 688
                    I believe he's talking about e30tech.
                    Build Thread
                    Parts Thread
