So after installing a supposedly rebuilt engine it turns out it has a blown head gasket or cracked head. Got oil in my coolant tank after running the car for 10min. Anyone had a rebuilt head laying around?
Possibly a rebuild head for 89 325ix
We don't have anything laying around but if you're interested in a quality head rebuild we can take care of that! www.bimmerheads.com -
Before you start buying parts, you should figure out what’s actually wrong.2006 GMC Sierra 2500HD 4WD LBZ/Allison
2002 BMW M3 Alpinweiß/Black
1999 323i GTS2 Alpinweiß
1995 M3 Dakargelb/Black - S50B32/S6S420G/3.91
1990 325is Brilliantrot/Tan
1989 M3 Alpinweiß/Black
sigpicComment
Cracked heads put coolant in the oil since the high pressure from the cooling system forces coolant into the cam valley, then mixes with oil. Do a coolant system flush with degreaser and run it again.Comment
Thanks for the tip. Do the flush after the new head is installed I'm assuming?Comment
I meant now so you can diagnose properly. If the head is indeed cracked then once the coolant is pressurized, you will see it bubbling from under the camshaft with the valve cover removed.Comment
