WTB: E30 M3 5-lug swap parts
  • Karlspackler
    • Jun 2006
    • 510
    Yup, I need the parts. All of them :p
  • Van Westervelt
    • 9365
    Good luck. Maybe hit up the dealer.
    • Karlspackler
      • Jun 2006
      • 510
      Yeah, the parts I will buy new are-
      Rotors
      Pads
      Struts and assemblys
      Coilovers
      All bushings
      I am looking for used:
      -Calipers- Good or bad (I can rebuild them)
      -E32 750 Master Cylinder
      -Do I really need the pad wear sensor????????
      -Front and rear swaybar
      -Front control arm assemblies and rear trailing arm assemblies
      I dont think I am forgeting anything.......
      • Van Westervelt
        • 9365
        You do not need:
        front and rear sway bar (same just a little different size. better to go aftermarket imho)
        front control arm assemblies (control arms and tie rods are the exact same too)
        Want but dont need:
        e32 750 master cyl (nice upgrade, but not necassary. my stock one is just dandy. brakes pretty quick/hard :) )
        rear trailing arm assemblies (there are easier and less expensive ways to do this, I can count 3)
        Pad wear sensor (use the e30 m3 one)
        Will need:
        Calipers front and rear
        All the items you listed you plan to buy new
        • Karlspackler
          • Jun 2006
          • 510
          Originally posted by E30 Groupie
          You do not need:
          Want but dont need:
          Will need:
          Thanks mang.
          So I dont need the entire front control arm assembly? What do I need then for the front?
          I intend on doing the master cylinder upgrade just because.
          I dont think I will use the pad wear sensor.
          What should I do in the rear that you are sugesting?
          • FredK
            • 14759
            In the rear, you can just get M3 hubs. The TAs are essentially the same.
            • Karlspackler
              • Jun 2006
              • 510
              Yeah, but I was told unless you have a press for the lolipop bushings, it is just easier to replace the whole damn thing.
              Is this really that hard to replace those? Doesnt Treehouseracing have some kind of bushing that makes this easier?
              • alex
                • 2024
                I'll be selling suspension from this car in a few weeks.
                • Karlspackler
                  • Jun 2006
                  • 510
                  http://www.behindmatrix.com/e30/foto...924/f00924.htm
                  is it an e30 m3 swap or e36? I am not really interested in the e36.
                  I would rather pay more and have it done right.
                  • alex
                    • 2024
                    E30.
                    • ToplessE30
                      • 4791
                      Both methods are essentially done right, but one is just simpler than the other. e36 suspension has its benefits as well although the caster is off.
                      Estoril E36 M3/4/5 | Toledo E53 X5 3.0 | LeMans E90 335D M-Sport
                      • gazellebeigem3
                        • Jun 2005
                        • 3712
                        The steering rack is a nice upgrade too. If you happen to find someone parting an e30 M3, just get it all. My list was something like this:
                        New: rotors/pads/sensors/rear hubs & wheel bearings/caliper rebuild kit x4/sway bar links x4/ oem m3 offset CABs
                        Used: front struts/calipers
                        Unnecessary but while i was at it: steering rack, sway bars, differential/750 mc
                        I did alot of preventative maintenance such as bushings and rebuilding the calipers. You might as well replace as much as you can while its apart so you dont have to mess with it for a while.
                        which to me, means that it is not done right. Not to mention that your offset will be not be equal even if you use ti parts in the rear.
                        • Karlspackler
                          • Jun 2006
                          • 510
                          ^ I feel the same way!
                          Thanks for the list. Yes, I had planned to either do an e36 or e30 m3 rack swap. What diff would you upgrade to? The 91' 318is I am having looked at had a 4.10 (small case I am guessing?)
                          • gazellebeigem3
                            • Jun 2005
                            • 3712
                            Yeah the m42s have small cases but limited slip was an option. Small case ls diffs are hard to come by so its easer to pick up a 4.10 out of a 325 or M.
                            • Karlspackler
                              • Jun 2006
                              • 510
                              hmm... well how do I tell if this car has a LSD?
                              Bump, who else has parts?
