Maybe. The valve reliefs are deeper because the pistons are higher compression, and BMW left the valve pocket depth the same (in relation to the cylinder head).
Since you shaved the block, you brought the pistons back to factory compression height, so all should be very close to factory limits. Your cam would be the deciding factor, and shaving the block backs the cam up a few degrees, so an aftermarket cam should be checked for VTP clearance. If you need more room, use an adjustable cam gear.
