M20 +2mm custom supertech intake valves
  • Liukas1992
    • Jul 2025
    • 5
    Long story short, I can not find anywhere +2mm (44mm) oversize intake valves, thinking to order from Supertech, these are one of the best valves you can get, weight, design and quality, but +2mm is minimum 50pcs custom order for 40euro/pcs.
    50pcs would be shipped to me in europe and than I would ship these in smaller quantities anywhere you need, expected delivery time ~4-5 months after manufactoring order is placed.
    Anyone would be interested in group buy?
    Also any idea where to find more m20 engine builders in one place😀?
  • digger
    • Nov 2005
    • 6156
    if you dont really want to organise a GB then as an FYI you can order from manley any size and QTY, mutiple materials, custom back cuts, and different keeper styles all within 4 week delivery normally. i have bought several sets of 6 in +2mm, +3mm
    • Liukas1992
      • Jul 2025
      • 5
      Ok, I will try to contact them.
      • digger
        • Nov 2005
        • 6156
        https://www.manleyperformance.com/cu...BUN_nfdnFEQA_E
        you are supposed to fill out this form below
        https://www.manleyperformance.com/wp...m_valves-1.pdf
        and email them back
        In order to fill out the form refer to
        https://www.manleyperformance.com/wp.../08/valves.pdf
        the first few pages describe materials available and page 42 and 43 of the document have the blanks available
        you will probably want to use 6.96 mm stems and so 11246 (race series) it can be shortened to suit m20 length without removing the hardened tip and max available head size is 48mm so easily fits 44mm
        you can change the margin, seat width and face dish from that shown on page 42/43 and can add back cuts (IMO mandatory)
        you can also use 7mm but will need additional effort to hone guides out
        bear in mind you can only shorten the length of some blanks so much (typically 38mm) so if you choose the "wrong" blank you may need to run a lash cap so the tip is hard enough as it may get removed if you shorten it too much
        • Liukas1992
          • Jul 2025
          • 5
          Long story short, I still in this hell, ordering 44mm valves.
          Any ideas why Manley does not answer to valve order requests? Ferrea same thing and Supertech raised minimal order from 50 to 100pcs.. what is happening😳?
          • digger
            • Nov 2005
            • 6156
            i have had to resend a couple times in the past. Can you just call them?
            • Liukas1992
              • Jul 2025
              • 5
              Calling them would be good idea, but I am located in europe and my english is not fluid, so email is much more confortable option.
