German Engineering Suspension GB
  • CHIF8008
    • 3447
    #211
    dangit. i should have waited for this instead of JOM's :(
    -FREEDOM- is cruisin at 80, windows down and listening to the perfect song-thinking "this is it"
    -The Beauty in the Tragedy-
    MECHANIC SMASH!!- (you all know you do it)
    Got Drop?? ;-)
    But of course
    E30s are know to be notoriously really really really ridiculously good looking
      • 37827
      #212
      Originally posted by einstein57
      Ok guys. Start PMing me your email address' so i can send out invoices.
      Sent.
      Classic BMW Specialists
      Santa Clarita, CA
      www.BimmerHeads.com
      • JGood
        • Jan 2004
        • 7959
        #213
        How do the sleeves "attach" to the strut housing? Is there a set screw? Seems like the whole sleeve would spin as opposed to just the adjuster...? I'm new to coilovers, so just curious.
        PM sent for invoice.
        e30 restoration and V8 swap
        24 Hours of Lemons e30 build
        • 2.7i/3.2M
          • Apr 2009
          • 59
          #214
          0. e46s54dr- (450f/650r)
          1. bloodshot-e30
          2. johnwoo-Coilovers, dust boots, and camber plates $455 (450f 650r)
          3. xoneslosentrax
          4. iwantspeed
          5. MR 325 (450f/650r w/camber plates)
          6. giantkeeper (w/ dust boots and camber plates 450f 650r - stiffer if available)
          7. noahp45 (Coilovers (dk spring rates yet) with Camber plates
          8. mach schnell
          9. mtlbloodshot (450f 650r coilovers, dust boots, eurothane uppers and camber plates)
          10. Luis325 (race rates)
          11. Cronopoulos (450f/650r or 500f/700r if available) camber plates, dust boots, rsm's...
          12. EThirty318i (450f 650r coilovers)
          13. jasonsnoddy (everything but keyless entry, 450f 650r)
          14. Puma (will be convinced by the goat)
          15. nebulous123 (Coilovers 450f 650r, dust boots, and camber plates)
          16. robert23 (450f 650r)
          17. der affe (500f 700r in a 6" spring)
          18. 6gen91 (stiffest setup )
          19. djjerme (450f 650r - possibly camber plates if the one's I got won't work..)
          20. e46s54dr (450f/650r + dust boot) edit: if stiffer rates are available, I'll take those.
          21. Brian D (300f 500r 6" springs + dust boots)
          22. Den_k321 ( 450f/650r )
          23. e30gentry no modification needed (450f 650r) dust boots and camber plates
          24. RagtopE30 (450f/650r or 500f/700r if available) camber plates, dust boots, rsm's
          25. IronmanE30 (pending discussion at the CarBeQue)
          26. howdyhoayman (don't know what spring rates yet but will get stiff af ones with camber plates)
          27. pputkowski - Coilovers (300f/500r), dust boots, and camber plates
          28. trackjunkie21- Coilovers (450f/650r)
          29. Robiniscool
          30. mhuyn h- Coilovers (450f/650r)
          31. Kwill22- coilovers (450f/650r) camber plates dust boots
          32. Sonj91- coilovers (450f/650r)
          33. dave.a.cote - coilovers (450f/650r) camber plates dust boots
          34. spidmang - Coilovers (450f/650r)
          35. IRUNEDM - coilovers (450f/650r) camber plates dust boots
          36. xAZxE30x - Coilovers (500f/750r if i can get that) Camber plates, dust boots
          37. Luis.e30325es- coilovers (450f/650r) and dust boots
          38. Fusion - coilovers (450f/650r) and dust boots (international shipping, not in a hurry)
          39. JGood - Coilovers (450f/650r) camber plates and dust boots[/quote]
          40. mo diesil
          41. artfunk007
          42. ADCD875 - coilovers (450f/650r) and Dust Boots
          43. noe30 - Coilovers (45/650) and dust boots
          44. Harry's e30 (450f/650r) possibly dust boots and camber plates
          45. 2.7i/3.2M (450f/650r)
          • e30slidewayz
            • 813
            #215
            1. bloodshot-e30
            3. xoneslosentrax
            4. iwantspeed
            8. mach schnell
            29. Robiniscool
            40. mo diesil
            41. artfunk007
            46. e30slideways - Coilovers, dust boots, and camber plates $455 (rates pending)
            • einstein57
              • Jun 2007
              • 10780
              #216
              1. bloodshot-e30
              3. xoneslosentrax
              4. iwantspeed
              8. mach schnell
              29. Robiniscool
              40. mo diesil
              41. artfunk007
              47. marco 325 a
              The sleeve is an exact fit to the strut tubes. I usually have to give them just a slight love tap to get them on. Usually the layer of paint i spray after cutting off the perch is enough additional girth to really lodge them in place. If you live in the rust belt then you might want to apply some adhesive to the inside of the sleeve. Just a dab of liquid nails or something similiat. Just a dab because there is pretty much 0 clearance. The possibility of build up can make the adjusters a little harder to adjust if you don't clean them periodically.
              www.gecoils.com
              • thebutcher37
                • 2877
                #217
                1. bloodshot-e30
                3. xoneslosentrax
                4. iwantspeed
                8. mach schnell
                29. Robiniscool
                40. mo diesil
                41. artfunk007
                46. e30slideways - Coilovers, dust boots, and $455 (rates pending)
                47. marco 325 a
                48. thebutcher37 - Coilovers (???F/???R) most likely camber plates as well.
                Transaction Feedback
                • mo diesil
                  • Jan 2011
                  • 275
                  #218
                  i would like the 450f 650 r setup please, what was the estamite on camber plates and when should we expect to see the coils?
                  • einstein57
                    • Jun 2007
                    • 10780
                    #219
                    they should be done in time for the holidays
                    www.gecoils.com
                    • mtlbloodshot
                      • Jul 2011
                      • 761
                      #220
                      When do you need the payment? I got your invoice but you wrote no rush on the payment
                      MY BUILD THREAD
                      http://www.r3vlimited.com/board/showthread.php?t=235231
                      INSTAGRAM : @luchcolaneri
                      • noahp45
                        • Jun 2011
                        • 107
                        #221
                        what he said
                        • einstein57
                          • Jun 2007
                          • 10780
                          #222
                          Send them in when your able to. I've received emails from numerous people saying they need a week or two to settle the funds. So lets try and get all the payments for the coils in by the end of this month.
                          www.gecoils.com
                          • e30gentry
                            • 608
                            #223
                            I got the JOM and now going to get these. JOM isn't for my liking.
                            • e30gentry
                              • 608
                              #224
                              Where are we sending money to? Or are we still waiting on the "50" mark?
                              • einstein57
                                • Jun 2007
                                • 10780
                                #225
                                Pm me your email address and I'll send you an invoice. We are at 49. That's as good as 50 if you ask me.
                                www.gecoils.com
