German Engineering Suspension GB
  • PNWDan
    • Feb 2011
    • 1326
    #931
    Originally posted by IRON-E
    Measurements of?
    Sorry. what is the measurement from center of the front wheel to fender for reference?
    1987 Alpinweiß 325is
    Like the PNW E30 Local Crew Facebook page
    • IRON-E
      • 16548
      #932
      As of now is pretty high, but I'm out and about with family today. Will get you #s tomorrow.
      @IRON-E30 aka Edwin:D
      • noE30
        • Jun 2008
        • 2260
        #933
        Installed the rear coils with my new IX bilsteins, everything installed fine. I set the adjuster completely down and i left both the adjuster and lock ring installed. You can definitely go low in the rear, granted my car is a late model.
        Flickr
        @michael.colby on Instagram
        "All he needed was a wheel in his hand and four on the road"
        • einstein57
          • Jun 2007
          • 10780
          #934
          1 original group buy slot opened up. Next person to use the original code r3v280 gets their kit for $280.
          www.gecoils.com
          • PNWDan
            • Feb 2011
            • 1326
            #935
            Damn lol.
            • GrifM3
              • 26
              #936
              I'll take them, PM sent.
              GrifM3
              • einstein57
                • Jun 2007
                • 10780
                #937
                Spot filled by grif
                www.gecoils.com
                • mbonanni
                  • Sep 2011
                  • 6236
                  #938
                  Dangit.
                  • graphikg
                    • Jan 2008
                    • 1614
                    #939
                    If you want the 6" front springs I can send them out Monday.
                    Ill just take whatever the group buy deal was.
                    • einstein57
                      • Jun 2007
                      • 10780
                      #940
                      The group buy deal was to meet expectations. If you expected a nice drop , have race camber plates,or just wanted a nice kit to use for sectioning your tubes then the 6" springs are for you. If you were expecting to be stanced right out the box with 0 modifications then the 4" spring is for you.
                      www.gecoils.com
                      • 801coppertop
                        • 293
                        #941
                        So if I don't want to be stanced, I shouldgoo with 6"? I don't want to have to cut the struts but I wanna be hr oe or a little lower...?
                        • einstein57
                          • Jun 2007
                          • 10780
                          #942
                          Correct. If you decide to add camber plates at a later date it should put you in tire tuck country.
                          www.gecoils.com
                          • ohthejosh
                            • 4963
                            #943
                            Nigel, quick question. If I order a set with a 4" spring that will allow me to have that stanced look on its' lowest setting? I will have room to raise the car if need be yes?
                            SO MUCH MORE TO DO!!
                            IG: ohthejosh
                            LEGIT CHECK ME BRUH
                            BUYER FEEDBACK THREAD
                            • einstein57
                              • Jun 2007
                              • 10780
                              #944
                              You will be able to bottom out the shocks on the lowest setting and have a a little over an inch of gap on the highest setting.
                              www.gecoils.com
                              • 801coppertop
                                • 293
                                #945
                                Are the rates for the 6" the same. If so I think I may do those because I do plan on getting your camber plates when there out. And I'm fine with the minor drop for the time being.
                                Edit: did some back reading, there same rate. I would like 6 in springs. Thanks for all your help!
